Looking for a first pvr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-07-2012, 09:00 PM - Thread Starter
magnus101's Avatar
Hello,
I have been searching the internet, looking for my first pvr.
I do not need it to record in HD.
And I do not need much recording time. Maybe 20 hours.
I would like to spend maybe $120 or under.
I could buy a refurbished box also.
However I do not want a monthly subscription.
I could record like an old vcr. Put in time and channel number.
But if there was a free on screen menu that would be great.
And I would need an IR control to set the cable box.
I would prefer HDD, but a dvd burner would also be ok.
I have searched everything from Hauppauge to Philips DVDR3455H (later on this page)
Any ideas?
thanks for any help
magnus101 is offline
post #2 of 2 Old 11-08-2012, 09:47 AM
profhat's Avatar
The Magnavox 53X series will work for you except for:
1. No IR control.
2. Cost, but maybe a refurbished unit will do the trick.
profhat is offline
