Number of Chapters on DVD-R - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-10-2012, 03:44 PM - Thread Starter
ulrich13's Avatar
I have been transferring short video segments from HDD to DVD-R on my 515.
If there are 5 segments, the 515 indicates that there are 5 titles on the DVD-R but when I play it back on a DVD player, that player indicates that there are 10 titles and it plays everything through twice. Can anyone explain this?
ulrich13 is offline
post #2 of 12 Old 11-10-2012, 03:52 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Is the disc Finalized?
wajo is offline
post #3 of 12 Old 11-10-2012, 03:55 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
The five titles were not cleared off your dubbing list. That way you dubbed the same titles twice to the DVD.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #4 of 12 Old 11-10-2012, 04:23 PM - Thread Starter
ulrich13's Avatar
Yes, the disc is finalized. If it were not I don't think the DVD player would play it.
ulrich13 is offline
post #5 of 12 Old 11-10-2012, 04:30 PM - Thread Starter
ulrich13's Avatar
They were dubbed only once. About an hour at fast speed, that's all that would fit. Playing them on the 515 shows 5 titles.
I have 7 discs like this.
ulrich13 is offline
post #6 of 12 Old 11-10-2012, 05:29 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
What is the length of each title (hh:mm:ss) and the rec mode?
wajo is offline
post #7 of 12 Old 11-10-2012, 07:00 PM - Thread Starter
ulrich13's Avatar
The titles vary from between one and two minutes and over 30 minutes each. Record mode is HQ.
ulrich13 is offline
post #8 of 12 Old 11-10-2012, 07:10 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I was hoping for the length of each title to see how that might fit into your doubling up, or not, and your filling the DVD, or not. The "HQ" is the other big item to know.
wajo is offline
post #9 of 12 Old 11-10-2012, 07:50 PM - Thread Starter
ulrich13's Avatar
Here's an example. Disc #4. 28:33, 19:39, 7:46, 7:48, and 1:07
Disc spaced used is 1:04:54 That's about all there was room for.
ulrich13 is offline
post #10 of 12 Old 11-10-2012, 08:29 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Wow, 1-sec below the HSD max. of 1:04:55... cutting it close!
That doesn't explain the doubling up, but the HQ might have something to do with it in relation to the playing machine. Some can't handle HQ bit rate nicely, and some might not see the +V R-mode files correctly.
What brand and model of other player sees the extra files?
Do you have any other non-Mag players to try it on?
wajo is offline
post #11 of 12 Old 11-10-2012, 09:14 PM - Thread Starter
ulrich13's Avatar
It is a Toshiba SD-5000. Maybe 10 years old. I will hook up another one and check it when I can.
It does not repeat when playing it on my computer.
ulrich13 is offline
post #12 of 12 Old 11-10-2012, 09:21 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
That sounds suspiciously like a player that can't handle the high bit rate of HQ... here's hoping!
wajo is offline
