Why my JVC DVD recorder will only record for 30 seconds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-14-2012, 07:42 AM - Thread Starter
MillerCrosses's Avatar
So it will only record for short time, usually 30 seconds, any advice?
MillerCrosses is offline
post #2 of 4 Old 11-14-2012, 08:38 AM
CitiBear's Avatar
Quoted: 103 Post(s)
Liked: 91
You didn't give enough info to base advice on. There are several possibilities to explore.
What country do you live in?
Which model JVC?
Which type of media (-R, +R, -RW, +RW, DVD-RAM)?
Which brand of media?
Is this happening with different types and brands of blank disc, or have you only tried one?
Using the JVC tuner, or line inputs?
What are you trying to record? Off-air broadcast from an antenna, direct from cable wire, from satellite box, from cable box? Are you trying to copy a VHS?
CitiBear is offline
post #3 of 4 Old 11-14-2012, 11:11 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
Agreed. The more detailed information, and the more specific you are, the more likely we can help you. Specifically, what is your signal source, and how is it connected to your recorder, and how is your recorder connected to your television? Are you using HDMI, component, composite?
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #4 of 4 Old 12-01-2012, 05:33 PM
maloku's Avatar
help ...
I have a JVC DR-MH30SE Video Recorder and I have a problem with its ignition ... after you plug in show "LOADING" we do not function at all. Can you tell what steps should be taken to fix this problem please ...
Y.MALOKU-KOSOVO
PS. sorry for my bad English
maloku is offline
