Slim Jewel Cases? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 12-01-2012, 01:42 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I'm presuming a lot of people here store at least some of their DVDs in the CD/computer size jewel cases (versus the larger DVD cases).
Are there any recommendations where to get some decent slim jewel cases? I finally used my last one & did some searching for price & availability. To me a jewel case was a jewel case. But there sure are a lot of negative reviews about being flimsy & hinges easily breaking, etc.
I have some Verbatim black DVD cases & they actually smell & not in a good way. So don't want to end up with smelly plastic jewel cases.
All the B&M stores are around me so if anyone has suggestions as to what is decent or what to stay away from I'd appreciate it.
Thanks in advance.
Mike99 is offline
post #2 of 29 Old 12-01-2012, 06:21 AM
fritzi93's Avatar
Liked: 41
My local Wal-Mart has clear slim jewel cases. I forget the brand name. There are always a couple broken ones in a 30-pack, but they're cheap enough.
Other than that, if you don't mind ordering online, there's Meritline, Rima, Supermediastore, etc.
fritzi93 is offline
post #3 of 29 Old 12-01-2012, 06:28 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
joed32 is offline
post #4 of 29 Old 12-01-2012, 06:55 PM
RichardT's Avatar
Location: Clarkston, Washington (State), Southeast corner
You have some good answers to your question. Individual cases are good for distribution discs, those you give away.
I have problems with my own discs, What's on them? and Where is it? I just finished cataloging my first 155 discs, with 1 to 6 (or more) titles on each disc. I've numbered each disc and am storing them in 12-disc cases. I have the Start and End disc # on the case spine, so I'll be able to look up the title in my catalog and go directly to the disc. I record a bit from Public Television; do I already have this program recorded? Hopefully, my catalog will easily answer that question. I also assign a "Category", the machine it was recoded on, the mode (High Speed, Flex Record, . . .), and the 8x, 4x, or 16x disc rating.
Trying to get my wife to classify and/or organize her Sewing and Cooking discs.
RichardT is offline
post #5 of 29 Old 12-03-2012, 12:12 AM
kjbawc's Avatar
Mike99, I hate jewel cases. they are flimsy, and hard to use. Poly cases are where it is at. The slim ones are easiest to find. Super Media Store and Rima usually have them. They are the same size as jewel cases, but they are much stronger. You can get them with a plastic outer sleeve, which makes it much easier than jewel cases, to install your cover. You can find them to hold two, four, and even 6 DVDs, making it convenient to package a season of TV shows, or a series of films.
kjbawc is offline
post #6 of 29 Old 12-03-2012, 01:25 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I have previously purchased discs from supermediastore.com. I just hate to pay shipping on a package of jewel cases, & possibly get some broken during shipping.
But I did try to look at what they have but am having trouble searching supermediastore. Frequently I'm stuck on an empty page & it states transferring data. I've walked away & came back & it's still transferring data. It does have Supermedia's name on it but it's blank where the products are suppose to be.
The link provided by joed32 does the same thing. IOW just a constant empty page.
I've tried this for the last few days with the same results. Since I don't have problems with any other website I have to presume supermedia has a problem. I'll try again later.
Mike99 is offline
post #7 of 29 Old 12-03-2012, 04:40 AM
Rammitinski's Avatar
Amazon (w/free shipping).
Fry's, Office Depot, Staples, Office Max, Sam's, Costco.
Have no idea how any of them are, but their websites should have some reviews.
Rammitinski is offline
post #8 of 29 Old 12-03-2012, 11:28 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
The slim cases I use are these.
http://www.supermediastore.com/product/u/cd-case-dvd-case-poly-case-slim-double-200
They are 5.2mm thick, and store two DVDs per case.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #9 of 29 Old 12-03-2012, 11:03 PM
kjbawc's Avatar
Aahhh! Another polycase guy!
kjbawc is offline
post #10 of 29 Old 12-04-2012, 06:35 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
That's strange because I just clicked on it and it was fine. Have you tried using Google to search and the clicking on the link there?
joed32 is offline
post #11 of 29 Old 12-04-2012, 07:14 PM
kjbawc's Avatar
When I buy poly cases, I buy enough so that shipping is free.
kjbawc is offline
post #12 of 29 Old 12-05-2012, 11:09 AM
Quoted: 111 Post(s)
Liked: 86
If you prefer, a very similar item is also available with two clear sides, so you can see through the shell to what is printed on the disks. The ones I listed above have a transparent sleeve for placing a label. These are more brittle plastic, like a jewel case, so they are more prone to having a hinge break, but they are what they are, and at 5.2mm for two disks, they are the most compact jewel-like cases I know of.
http://www.supermediastore.com/product/u/slim-clear-double-cd-jewel-case-200
The clear ones are bout $0.23 each, the black ones are only $0.115 each, which is about the least expensive jewel-type case Supermediastore sells. At two disks per case, it is twice as cost effective as this single disk case:
http://www.supermediastore.com/product/u/mini-cd-dvd-slim-jewel-cases-8-cm-fc-200pks
Luke
post #13 of 29 Old 02-12-2013, 12:46 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Here's what I ended up getting from Staples, 100 slim cases for $19.99. But wait there's more.
http://www.staples.com/Staples-5mm-Slim-Jewel-Cases-100-Pack/product_478455
I've been saving up ink carts for quite some time, figuring to "cash" them in at some point in time. I turned in 10 carts to Staples & eventually got $20 in Rewards dollars which I used for the cases. They deduct the Rewards from the $19.99 which meant I owed nothing, & since I paid nothing there was no tax either. I ended up with 100 cases for free.
Mike99 is offline
post #14 of 29 Old 02-12-2013, 01:38 PM
tomwil's Avatar
Liked: 26
Ordered the 1000 pack, using code BD509235 for $5 off. They seem to work really well, and should help decrease the storage area I need by half.
Thought about getting the clear ones, but they were twice the price, and the black cases should help eliminate light exposure.
Thanks for mentioning these! I was originally using the slim jewel cases, but will now transfer to the poly cases.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #15 of 29 Old 02-13-2013, 01:09 AM
Quoted: 111 Post(s)
Liked: 86
You're welcome. I have enjoyed using them, and I hope they work out for you.
Luke
post #16 of 29 Old 02-13-2013, 07:52 AM
dare2be's Avatar
dare2be is offline
post #17 of 29 Old 02-13-2013, 09:04 AM
tomwil's Avatar
Liked: 26
Originally Posted by dare2be View Post
I agree. The closest they offer is the 5.2mm Slim Double Clear CD Jewel Cases (hard plastic) at double the price.
tomwil is offline
post #18 of 29 Old 02-14-2013, 12:01 AM
Quoted: 111 Post(s)
Liked: 86
Even at $0.23 per unit, it's not a bad deal for the clear ones. I agree, the black ones keep out the light.
Luke
post #19 of 29 Old 02-14-2013, 07:01 AM
dare2be's Avatar
Well, I went ahead and took the plunge with 3 orders of the 5.2mm black poly double cases. Now I just need to come up with a new methodology for labeling them. Before it was just a black sharpie numbering the front of the clear plastic 5mm jewel cases. I guess I could use a silver sharpie.
dare2be is offline
post #20 of 29 Old 02-14-2013, 07:48 AM
plplplpl's Avatar
Liked: 24
For quickies / giveaways / audio CDs, I often use the Staples 50-pack or its Walmart equivalent (with hub printable watershield white or silver inkjet Taiyo Yudens). I haven't seen the 100-packs at brick & mortar locations in Canada.
For more serious projects, I'll make a proper case with printed insert.
plplplpl is offline
post #21 of 29 Old 02-14-2013, 10:57 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I got the 100 pack at a brick & mortar store in the Chicago suburbs. It has 50 clear & 50 assorted colored cases.
Mike99 is offline
post #22 of 29 Old 02-16-2013, 11:39 PM
kjbawc's Avatar
Well, they ARE made, and, sometimes SMS has them. They are also usually available from Meritline. I prefer the clear poly with a clear sleeve. I print my own labels, and slip them under the sleeves. I also buy them from LDBMART.com. There are also quad poly cases available, CD sized. I use those for TV series, and film series.
kjbawc is offline
post #23 of 29 Old 02-18-2013, 11:40 AM
doswonk1's Avatar
Quoted: 12 Post(s)
As for durability, I've found that when I drop any jewel case on a hard surface, it breaks. Plus, even the "slim" cases take up more shelf/drawer space than I care to give up these days. So mostly what I use now are these polyvinyl sleeves (also in pretty colors). Protects the disc, won't shatter when I drop it, as flat as you can get. I got a couple of packs as freebies from Supermediatstore a few years ago, and I've since bought more, while the last 100 pack of slim jewels I got at Staples a couple years ago hasn't even been opened.
doswonk1 is offline
post #24 of 29 Old 02-20-2013, 02:17 PM
dare2be's Avatar
Just got these in the mail yesterday. I wish I had known about them sooner. Now just gotta figure out what to do with my hundreds of old single, hard plastic slim jewel cases. smile.gif
dare2be is offline
post #25 of 29 Old 02-21-2013, 12:20 AM
Quoted: 111 Post(s)
Liked: 86
I have the same problem. what do you do with hundreds of single slim-line jewel cases? The plastic is rather brittle, and the hinges are pretty small, so they are not very robust--their impact resistance is pathetic. Overall, a rather poor design really.
Luke
post #26 of 29 Old 02-21-2013, 06:48 AM
dare2be's Avatar
First impression: They do have an odor, but not unbearable. I hope that whatever is causing that odor doesn't interact with the DVDs themselves and shorten their longevity. I have noticed that a handful of them will not stay closed, but overall, it's worth it to double my storage space. Having the clear outer poly sleeve on both sides is a nice touch, making labeling very easy and flexible.
dare2be is offline
post #27 of 29 Old 02-23-2013, 10:52 PM
kjbawc's Avatar
Welcome to the wonderful world of polycases with sleeves! As to those fragile slim jewel cases, use those when you give DVDs to friends.
kjbawc is offline
post #28 of 29 Old 02-24-2013, 12:38 AM
tomwil's Avatar
Liked: 26
I have noticed that a handful of them will not stay closed ...
The hubs that hold the discs, interlock also when the center of the case is gently squeezed together. After doing that, the case will remain closed.
tomwil is offline
post #29 of 29 Old 02-24-2013, 07:31 PM
dare2be's Avatar
I realize that, but I'm talking about the 4 tabs, 2 at each outer corner. Some of them were broken off, so the corners would not stay completely closed, leaving a gap for dust to collect. About a dozen of them out of a 200-pack were like that, and the cardboard box they came in was slightly damaged...I'm sure that is what caused the broken tabs. I'll be emailing SuperMediaStore to see if they will do anything about it. At this point, I wouldn't worry too much about it, but it can't hurt to ask.
dare2be is offline
