Replacing harddisk in philips dvdr3455h - AVS Forum
post #1 of 7 Old 01-01-2013, 03:44 AM - Thread Starter
assuraq's Avatar
Hi Everyone
I have a philips dvdr3455h and the 160G harddisk is not working. When searching for info on how to replace the harddisk, I came across the following thread:
http://www.fixya.com/support/t1249059-dvdr_3455h_97_hard_disk_unable_reboot
May I know which solution is correct?
a. The 1st solution states that it is impossible to replace a bad harddisk because it is not possible simply insert a new harddisk. It has to be pre-loaded with some software.
b. The 2nd solution states that it is possible to replace the harddisk by simply burning the firmware to a CD and then follow the on-screen prompts
Actually I have tried solution "b" but using a fat32 formatted 200G harddisk and the firmware CD, my recorder hangs at the word "load". I am trying to confirm if it is really necessary to purchase the following pre-prepared harddisk from ebay:
http://www.ebay.com/itm/Philips-DVDR3455H-37B-IDE-250GB-HD-Ready-Install-New-1-year-Warranty-/221155891887?pt=DVD_Players_Recorders&hash=item337deb1aaf
Quek
assuraq is offline
post #2 of 7 Old 01-01-2013, 03:47 AM
Weijas's Avatar
which universal remote control for DVD3455H?
Without remote the DVD recorder is seems useless.
Thank you
Weijas is offline
post #3 of 7 Old 01-01-2013, 04:27 AM - Thread Starter
assuraq's Avatar
Hi Weijas
No, I do not have any info for universal remote control for dvdr3455h. Perhaps you can start a new thread for your issue.
Quek
assuraq is offline
post #4 of 7 Old 01-05-2013, 01:47 AM - Thread Starter
assuraq's Avatar
Hi Everyone
I have finally managed to successfully replaced the 160G harddisk in my dvdr3455h/97 with a 200G harddisk. There is no need to purchase the harddisk from ebay. No special setup is needed for the harddisk. The harddisk can be replaced as follows:
a. Burn the firmware on a disc
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVDR3455H/97&scy=in&slg=en
I used firmware R19.15 and Nero6 with the following settings:
File name length : Max of 11 = 8+3 chars (ISO level 1)
Format : Mode 2/XA
Character set: ISO 9660 (standard ISO CD-ROM)
Multi-session : No
Joliet : Yes
Allow path depth of more than 8 directories : Yes
Allow more than 255 characters in path : Yes
Allow more than 64 characters in Joliet names : Yes
No special disc label is needed.
Burn-speed : 16x using samsung dvd burner
Burn setting : Disc-at-once
My initial disc was created using a brand of cdrom named "A1Pro". It turned out that the dvdr3455r cannot read this brand of cdrom. The problem was resolved after switching to maxell cdrom. As there are different models of dvdr3455h (e.g. dvdr3455h/37, dvdr3455h/97), care must be taken to download the correct firmware.
b. Format new hardisk to fat32 using swissKnife tool. Quick format will be fine. I suspect that this step might not be needed but did not confirm it.
c. Insert firmware disc into dvd recorder. The display should display the words PHILIPS->LOAD->COPY->BOOT.
d. Follow on-screen prompts
e. Go to "Setup" menu and re-format the harddisk by using the function to erase all items on the disk. If this is not done, the dvd recorder does not allow recording.
Hope that this will be helpful for others.
assuraq is offline
post #5 of 7 Old 01-05-2013, 07:15 AM
krazykanuck's Avatar
Congrats and good work assuraq. Does the 3455 recognize the full capacity of the 200g hdd you've installed?
krazykanuck is offline
post #6 of 7 Old 01-05-2013, 04:21 PM - Thread Starter
assuraq's Avatar
Hi krazykanuck
Yes, it does. "Harddisk info" function in the "Setup" menu reports that the harddisk has capacity 160Gb but also states 188Gb of remaining space.
Best regards
Quek
assuraq is offline
post #7 of 7 Old 11-30-2013, 08:29 PM
susanspain's Avatar
Hi, I have the I have Philips DVDR3455H/97 with the dvdr out of order. The model no. shown on the HD is "E143838 D5.1 CLOSED".
Does anyone know where I can source a replacement HD for my machine? (used OK!)
I have seen one on EBay (UK - as this is where I live)... but it is the D5.2 version.
Is this likely to fit/work in my machine?
(It came out of a DVDR3575H
Part no 313924800333
5VC0730350680
Model d5.2 Closed. E143838 ) someone has broken up their machine and is selling the working parts.
Any feedback gratefully received!
susanspain is offline
User Tag List
