Which universal remote control for DVD3455H - AVS Forum
post #1 of 2 Old 01-01-2013, 03:52 AM - Thread Starter
Weijas's Avatar
Hi,
My remote control for DVD3455H is dead beyond repair.
Any body can help?
Please let me know where and how can I find a replacemnet.
Thank you
Weijas is offline
post #2 of 2 Old 01-02-2013, 02:22 PM
mdavej's Avatar
Quoted: 88 Post(s)
Liked: 279
Get an RCA RCRP05B or BR for $12-$15 just about anywhere and use DVD code 1340. That will cover most commands. You can get them all by using the following Advanced codes (see Manual 9xx programming instructions in my Wiki link to add them):
Code:
num_0        00018
num_1   00010
num_2   00034
num_3   00026
num_4   00242
num_5   00234
num_6   00002
num_7   00250
num_8   00082
num_9   00074
CH+     00194
CH-     00186
Power   00050
Play    00051
Pause   00051
rewind  00075
ffwd    00083
Stop    00139
Record  00149
angle   00230
Menu    00112
up_arrow        00208
down_arrow      00200
left_arrow      00224
right_arrow     00216
Select  00176
Skip+   00019
Skip-   00011
Display 00058
Last_ch 00097
Audio   00156
inputnext       00192
menuselect      00068
DVDRecord       00123
Exit    00022
InputDVD        00142
InputHDD        00158
repeat  00170
shufffle        00178
subtitle        00088
t/c     00076
timer   00189
inoputtuner     00094
inputusb        00020
zoom    00148
Harmony 200 or 300 is another cheap option. You can get the original remote HERE, but it's quite expensive. Otherwise try ebay.
mdavej is offline
User Tag List
