what size diemensions is the 515 exhaust air fan? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-10-2013, 05:49 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
what size is the 515 exhaust air fan?
I tryed to obtain the orginale fan however I was informed that that the fan is unavailable this was before anyone knew the 535 was being manufactored.
I'm planning on swapping the fan in the 515 w/ a better than OEM fan (computer fan)
orginale fan lasted a couple weeks after warrenty expired which isn't long for a fan expesialley on a DVR that was'nt used much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835119047
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
