Does recording quality vary much recorder to recorder? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 01-22-2013, 10:12 AM - Thread Starter
ragu0012's Avatar
Originally Posted by CitiBear View Post
No, there isn't, and no, you can't.
Thank you.
ragu0012 is offline
post #32 of 33 Old 01-28-2013, 10:56 AM - Thread Starter
ragu0012's Avatar
I've been using the EH59 for a week and LOVE it. so consumed with capturing old vhs tapes and editing and dividing that I still haven't burned a disc from it. Plan on doing that tonight.
One question though, for any of you familiar with all the features. In the play menu there is a Noise Reduction (NR) feature. Do you know whether that just affects the picture during playback, or will it alter the picture during capture/recording to the HDD? Is it safe to leave on at all times or when a VHS has no noise should i be sure to turn it off?
I personally cannnot tell the difference between picture with or without NR but my eye is not as trained as some of you.
ragu0012 is offline
post #33 of 33 Old 01-28-2013, 12:04 PM
jjeff's Avatar
Quoted: 696 Post(s)
Liked: 246
It's for recording from the line input and yes i leave it on all the time. It's kind of subtle but it does help with a noisy source like tape.
jjeff is offline
