Panasonic DMR-EH57 don't recognize DVD-R disc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-14-2013, 08:37 AM - Thread Starter
Sorin21's Avatar
After a long time, I wanted to see a few .avi files over my pana recorder. I burned a DVD disc using Nero 11 (DVD-ROM UDF).
However, after inserting a disc, I get a message that the disc is incompatible.
Several discs that I burned before I tried now and they work without problems.
So, what makes the difference between them?
Thanks in advance!
Sorin21 is offline
post #2 of 3 Old 01-14-2013, 10:55 AM
Church AV Guy's Avatar
Quoted: 117 Post(s)
Liked: 89
You haven't really given us enough informatiuon to even make a guess. Could you be a lot more specific?
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #3 of 3 Old 01-14-2013, 11:09 AM - Thread Starter
Sorin21's Avatar
I do not know exactly what you mean regarding the lack of information, but I'll try ...
So, xvid (or divx, .avi) movies are concerned. Burn them to a DVD-R disc, insert in the pana recorder and watch. Еach video file is in a separate folder. Even though pana can not read some file because of not supported codec, users in the menu see all the folders. Whether the file is played, does not affect to view folder.
But, in the current case, recorder immediately after insertion stating that the disc is incompatible.
Earlier I used something like that more often, lately not so much. As I recall, did not need any special procedures regarding burning, except that the disc must be finalized. So I did it this time. As I said, I used Nero 11 and selected DVD-ROM UDF option.
I tried previously recorded discs which i still own and they work without problems.
Sorin21 is offline
