Panasonic DMR-ES20 - image sized wrong, top and bottom cut off - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2013, 11:47 PM - Thread Starter
permutations's Avatar
My Panasonic DMR-ES20 isn't playing nicely with my 16x9 HDTV. It appears to think that the TV has a 4x3 aspect ratio, no matter what I tell it in Setup, and the tops and bottoms of everything is cut off. It's fitting the width of the picture to my TV screen, and since I have a widescreen TV, the 4x3 image is too tall. This goes for the Setup screen itself. I can't even see the label for the last item in Setup, which is where you set the TV screen aspect ratio and display options.
This is very annoying to me, and I don't know how to fix it. Is it a bug in the DMR-ES20, or is my DVD Recorder faulty? I did some test recordings from a VHS tape, finalized the disk, and played it in my Blu-ray player. The Blu-ray player correct displayed the 4x3 picture with black bars on the sides. (The resolution was dreadful, but that's because my VHS machine has only component output.)
Any ideas how to fix the picture size problem? I tried changing the TV aspect ratio setting to 4x3, but that didn't fix it. None of the TV display settings seem to have any effect.
permutations is offline
Old 01-16-2013, 11:08 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
This sounds very much like a TV setting, and not a DVD recorder setting. I wouldlook into what display mode you are using for that input. It's likely on stretch or expand.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Old 01-16-2013, 11:16 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Also if recording from a line output device(STB, DVR, etc.) I suspect that, plug whatever your recording from directly into your TV, WYSIWYG. No settings that I know of(on your model DVDR) that would effect recording in that manner, only playback.
jjeff is offline
Old 01-16-2013, 11:29 AM - Thread Starter
You're right - it's the TV! I thought I'd checked that, but it turns out that depending on what I'm looking at, the television has a different display setting. When I was looking at the DVD input, it was on a Zoom setting for some reason. When it was receiving cable STB input, it was on a different display setting. I didn't even know it did that.
Old 04-11-2015, 12:04 AM - Thread Starter
Belated update... I was not able to fix the problem with settings on either the TV or the ES20. The ES20 is telling something wrong to my TV, and I can't change the TV settings so it displays correctly. Sorry for not following up.
I found out today that Panasonic released new firmware for the ES20. Maybe they have fixed this bug.
http://www2.panasonic.com/webapp/wcs...PRD_CNT_007733
I haven't been able to try it yet because a capacitor blew the other day. I ordered a new one, and it shouldn't take long to swap it in. (Hopefully I won't screw up the soldering job.)
