not getting all cable channels on the mag 533 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-18-2013, 01:03 PM - Thread Starter
heydagny's Avatar
Hi there,
Used auto channel to set up channels from basic cable service. I'm getting most of the channels, except for three. Have rescanned and same thing happens. Any thoughts on how to get these three missing channels to show up?
heydagny is offline
post #2 of 5 Old 01-18-2013, 05:04 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Some of your cableco's "physical" channels your other devices get might be remapped to different "physical" channels in the Mag since it has a different tuner... it's a "hybrid" (switched" tuner that you have to switch between analog and digital channels.
First, look for CONTENT, NETWORK, CHANNEL CALL SIGN, & PROGRAM to see if what you're looking for might be on a different physical channel # in the Mag.
More detailed info here.
wajo is offline
post #3 of 5 Old 01-20-2013, 07:44 AM - Thread Starter
heydagny's Avatar
thanks for your reply. So I have basic cable 1 to 125 channels, but the basic channnels i want are at 192 and 704. Do I just punch those numbers in and they will show up?
heydagny is offline
post #4 of 5 Old 01-20-2013, 08:04 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The Mag has physical ANALOG channels 1-125 and DIGITAL channels 1-135. You have a remote "switch" (the DTV/TV button) to switch between the two types of channels.
If you have cable, you should have done an Auto Channel Preset > Cable (Analog/Digital) to see what unscrambled channels the Mag can tune by itself, without a cable box.
The cableco's high-numbered channels are VIRTUAL channel numbers that your Mag will RE-MAP, or assign to, its 1-125 or 1-135 PHYSICAL channels. SO, you'll have to do an auto channel preset then surf the Mag's channels and LOOK for the same content as in the high-numbered channels, as I stated above... i.e., you can't tune a PHYSICAL channel like 192 or 704, so you'll have to correlate the show content, network and channel name (TNT, NBC) or call sign (WABC, KRLA), etc. to see where those channels ended up in the Mag.
wajo is offline
post #5 of 5 Old 01-20-2013, 03:39 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
No, they might be remapped to a wide range of numbers. The channels you find will be those that are not scrambled by your provider.
Be patient when looking for digital "channels." There are potentially thousands of "channels and sub-channels" in the 1-135 range. The channels and sub-channels will appear at such locations as 87.4 or 118.22.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
