Philips 3575 - Larger HDD Possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-28-2013, 11:55 AM - Thread Starter
Breyean's Avatar
I just picked up one of these for $25 and it works great.
I have several Magnavox 2160s which I swapped out the hdd from 500gb ones.
I'm wondering if there's a similar way to swap out for a larger drive on the Philips 3575/37?
Breyean is offline
post #2 of 3 Old 01-28-2013, 11:57 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Same way as you did for the 2160's... here's the help file in case you need it.
500GB max. PATA or SATA w/PATA-SATA adapter in the models prior to the new 53x Series (which is 1TB max.).
7558037 is offline
post #3 of 3 Old 01-28-2013, 03:48 PM - Thread Starter
Breyean's Avatar
Thanks! I wasn't sure if I had seen this for the Philips.
I'll have to give it a try.
Breyean is offline
