Panasonic DMR-E85H - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-01-2013, 05:33 AM - Thread Starter
hawk2wp's Avatar
I found the usual c1270, c1271, c1272 capacitors bad and replaced them. I also had some other bad capacitors on the power supply board and a few on the video board and replaced them too. Now my unit powers up, goes though the self test, operates for about 1 minute and shuts itself down. Anybody experience this? Thanks
hawk2wp is online now
post #2 of 12 Old 02-01-2013, 10:29 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
I did have this happen to me once. It was something stuck in the fan. Is the fan turning?
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #3 of 12 Old 02-01-2013, 10:56 AM - Thread Starter
hawk2wp's Avatar
The fan doesn't come on right away. After the self-check the unit is normal for about 45-60 seconds then the fan turns on and that's when it shuts itself down.
post #4 of 12 Old 02-01-2013, 05:34 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Check the fan's power connection.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #5 of 12 Old 02-01-2013, 07:21 PM - Thread Starter
hawk2wp's Avatar
the fan connection seems to be fine. The fan turns on about a minute after the self test. the fan runs for 3-4 seconds then the fan and the unit shut down. I have 6.95 volts for the 3-4 seconds the fan runs. I disconnected the fan and it does the same thing with 6.95 volts at the pin for the fan power for 3-4 seconds then the unit shuts down.
post #6 of 12 Old 02-03-2013, 11:23 PM
Quoted: 111 Post(s)
Liked: 86
Sorry, but that was the only guess I had. The machine is sensing something is wrong, and shutting itself off.
Luke
post #7 of 12 Old 02-06-2013, 07:26 AM - Thread Starter
hawk2wp's Avatar
Thanks for the advice, it was worth a try!
post #8 of 12 Old 02-10-2013, 02:04 PM
jhvance's Avatar
Quoted: 12 Post(s)
Probably worth sending a message to mickinct about it to see if he's familiar with that failure mode, and what its likely problem source might be -- if it needs repair and you want to salvage its use, he's your man to properly take care of whatever ails it (this from personal experience with my E85H).
jhvance is offline
post #9 of 12 Old 02-11-2013, 04:40 AM - Thread Starter
hawk2wp's Avatar
Thanks, I've sent him 2 messages, but no response yet.
post #10 of 12 Old 04-13-2013, 07:11 PM
flyingfocus's Avatar
Hi
If you found out how to fix this, please let us know!
We suddenly had the same problem starting a little while ago after nearly 8 years of great use of the DMR-E85h
dan h
flying focus
portland, or
flyingfocus is offline
post #11 of 12 Old 04-13-2013, 10:46 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Originally Posted by flyingfocus View Post
Hi
dan h
flying focus
portland, or
I, too would like to know if mickinct had any thoughts on this or was able to resolve the problem(s). None of my many Panasonics go back to the 2004 model year (like the DMR-E85H) but one or two more recent models have had the same problem. After considering all the possibilities I deemed that there was a problem with the Digital PCB.
For the affected models I didn't have any known good COMPATIBLE Digital PCBs to swap into the machines. Where I did have a close known good Digital PCB replacement on hand I swapped in that Digital PCB with somewhat better, but still unsatisfactory results.
I reported this experimentation over several posts, beginning here:
http://www.avsforum.com/t/1082922/swapping-panasonic-dvd-drives-compatibility-considerations/0_60#post_15092330
DigaDo is offline
post #12 of 12 Old 04-14-2013, 03:06 PM
tomwil's Avatar
Liked: 26
Mickinct probably will not give out free advice, as it would affect his repair business, and rightfully so.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
