SCART adapters and the EH 69 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-02-2013, 09:53 AM - Thread Starter
Rmcwald's Avatar
I am attempting to utilize the SCART input (AV2)on my EH 69 with svideo to SCART adapters to no avail. I get the audio output but only black and white video. Tried an adapter from Amazon and then bought a second adapter from SVideo with the same result. I have a tendency to overlook the obvious but ......the svideo input (AV4) works perfectly. Any thoughts.
Rmcwald is offline
post #2 of 4 Old 02-03-2013, 12:28 AM
RichardT's Avatar
Location: Clarkston, Washington (State), Southeast corner
Have you set the "Connections" properly? This is typical for my EH59, same manual.
FUNCTIONS > OTHER > SETUP > CONNECTIONS, then select AV2 to S Video. See what that does for you. Page 60 of the manual. If you are outputting on AV1, you need to set that also.
RichardT is offline
post #3 of 4 Old 02-03-2013, 06:33 AM - Thread Starter
Rmcwald's Avatar
Thanks RichardT. I will check this out and post result.
Rmcwald is offline
post #4 of 4 Old 02-03-2013, 01:17 PM - Thread Starter
Rmcwald's Avatar
Works like a charm. Thanks again
Rmcwald is offline
