Losing some Comcast chaneels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-06-2013, 07:14 AM - Thread Starter
Waseem's Avatar
Hi All,
Recently I have been unable to view any Comcast channels above 5.1 using my Magnavox RMDR515H/F7. I discovered this when I tried to record a show while I was away only to record a blank screen.
Then i started to flip channels an all I got was these blank screen.
I can see 5.1 and below, but nothing above that.
Any ideas?
Waseem is offline
post #2 of 5 Old 02-06-2013, 08:01 AM
Westly-C's Avatar
Quoted: 357 Post(s)
Liked: 230
Rescan the channels. My local Comcast does this to me as well.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #3 of 5 Old 02-06-2013, 05:57 PM - Thread Starter
Waseem's Avatar
Thanks Westly-C
How often do we need to do this?
I hope Comcast will think of us before doing something so drastic.
Thanks again for solving my problem.
Waseem is offline
post #4 of 5 Old 02-06-2013, 08:55 PM
Westly-C's Avatar
Quoted: 357 Post(s)
Liked: 230
For me, this seems to happen nearly every 4 months. It almost happened tonight as I was setting the timer to record Arrow on the CW. My local affiliate carries syndicated basketball on Weds, so the CW lineup gets pushed back 2 hours each week. I cycled thru the line inputs as the Mag started up and saw black screen. Luckily, the clock's time was a few minutes fast, and I was able to stop the recording, and direct dial the digital ch which brought the signal back in without having to do a rescan with so little time before the show started.
But a rescan will be needed afterwards, to insure further timer recording goes without hitches like this.
Westly-C is offline
post #5 of 5 Old 02-07-2013, 01:41 PM
Liked: 62
It's not just Comcast. All the cable companies do it on somewhat frequent (but often irregular) intervals.
The majority of their customers rent a cable box that automatically updates the shifted channels to Comcast's (or Cox's or TWC's or whoever's) designated channel lineup so those customers never see the change, the channels are always where they expect them to be. Clear QAM users are basically out of luck and have to do the rescan from time to time. The cable companies couldn't care less about them.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
