Channel change in middle of timer recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2013, 09:15 AM - Thread Starter
dbrown3582's Avatar
Hi,
I got the Magnavox MDR537H in December, and have had no problems with it until last night. I always record Craig Ferguson, then watch him the next morning before I go to work. This morning, half way through my watching the recording of last night's Ferguson, the channel changed (you could see a "wipe" on the screen) and it started recording a different station.
I have no timer programs that overlap with my Ferguson recording schedule, and have recorded Ferguson every day, problem-free, since December.
My Magnavox unit is hooked directly into the coax first, then via HDMI to the TV.
Does anybody have any idea what could have caused this?
Dave
dbrown3582 is offline
post #2 of 4 Old 02-12-2013, 09:58 AM
Kelson's Avatar
Quoted: 1959 Post(s)
Liked: 1150
I take it that you are on cable. Could it be that your cable company just rearranged the channels, as they often do. Is that channel number your unit was tuned to, still the same network?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #3 of 4 Old 02-12-2013, 10:19 AM - Thread Starter
dbrown3582's Avatar
Yes, I am on cable. Good thought; I had also considered that the cable company rearranged the channels, but I checked, and the channels didn't change.
Some more info, in case it will help - I record Ferguson off of the CBS affiliate, which the QAM tuner picks up. Usually, when I turn the Magnavox on in the morning, it is still on CBS (in my case, channel 8.1) from recording Ferguson the night before. When I was watching my recording from last night, it changed from CBS to NBC (in my case, channel 13.1, so it actually started recording Fallon instead). When I stopped watching the recording, I noticed that the Magnavox was tuned to NBC.
post #4 of 4 Old 02-12-2013, 10:27 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I wouldn't worry about this kind of one-off event... my cableco likes to "play" with channel assignments, esp. dropping or adding digitals, moving them somewhere else for awhile then returning them to original slots. The Mag has no facility for "wiping" so that might be an additional clue? Also, late at night might be your cableco's preferred "play time"?
See if it becomes a "regular" occurrence or not.
wajo is offline
