Goodwill Philips dvdr3575h/37 for $20 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-17-2013, 01:30 PM - Thread Starter
Stonent's Avatar
I hit 2 Goodwills yesterday looking for an espresso maker and ended up finding a dvdr3575h/37 for $20 with a 10 day warranty. It had a dent in top but the lady said that it powered up.
I took it home and it came on just fine. I put in a DVD-R that had a movie on it and it started playing just fine. Unfortunately I have no remote and can't test anything other than DVD playing.
I took an old Uverse remote and found a Philips DVD code that worked for basic DVD control.
It has a Seagate 160GB drive in that that sounds good, so I've decided to order a used OEM remote from Amazon.
Is there anything I can test without having the real remote? If I press the info button on the Uverse I get a drop down menu with just information and the ability to change language while playing a movie.
Is there any way to test recording at all without the remote? The last person that owned it left it tuned to 11.1 which is the local CBS station, but reception is so poor here, I was never even able to get digital stations to stick on my digital TV or the separate decoder box I bought.
Years ago I had a Panasonic DVD recorder that was great but failed after a few years of really not ever using it more than about 20 times to record DVDs. It was a DMR ES something with the SD slot on the front. The main reason I got that recorder was the DVD-RAM ability for on the fly recording and pseudo DVR functionality.
Stonent is offline
post #2 of 15 Old 02-17-2013, 01:44 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
There are STOP, PLAY and RECORD buttons above the door on the right side. If you have any other Funai-manufactured devices, like other Magnavox, late-model Toshiba, Sylvania, Emerson, Symphonic, those remotes might be able to operate it.
wajo is offline
post #3 of 15 Old 02-17-2013, 08:04 PM
gastrof's Avatar
Quoted: 118 Post(s)
Aren't there still new remotes for that model out there on "replacement remote" websites?
I'm going looking for one.
EDIT:
Found it, first attempt.
$34, ships in one day.
http://www.replacementremotes.com/PHILIPS/Buy-NB526UD-996510003026-DVD-Recorder-DVDR-Remote-Control.html
gastrof is offline
post #4 of 15 Old 02-17-2013, 09:09 PM - Thread Starter
Stonent's Avatar
Stonent is offline
post #5 of 15 Old 02-17-2013, 09:10 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
wajo is offline
post #6 of 15 Old 02-18-2013, 01:52 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
No need to pay more for the remote than the player. And no need to order one either. A $20 harmony 200 from your local radio shack will do every function, as will a $10 RCA RCRB05BR from most anywhere. If you have cable TV, that remote will also do every function with a little programming. HERE are the codes for all functions. You can put any function on any button. Using shifted buttons, there's plenty of room for all functions.
mdavej is online now
post #7 of 15 Old 02-18-2013, 05:55 PM - Thread Starter
Stonent's Avatar
Well the uverse remote that I had only controls the player functions. It doesn't have a way to do any of the other functions.
Stonent is offline
post #8 of 15 Old 02-18-2013, 06:03 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
If you're considering a non-OEM remote, here's a help file on a $15 Philips universal learning remote that I know works very nicely with the Philips and Mag HDD/DVD recorders. Used to be found in Walmart stores and is available on Amazon.com... same or similar in the series are probably at other B&M stores as well.
wajo is offline
post #9 of 15 Old 02-18-2013, 06:43 PM - Thread Starter
Stonent's Avatar
Well I've got an original remote on the way, should have by the end of the week.
Stonent is offline
post #10 of 15 Old 02-26-2013, 08:47 PM - Thread Starter
Stonent's Avatar
Got the remote, everything seems to be working. The HD was full of random stuff, it started playing the Cleveland Show when I started it. The drive was completely full. Looks like recordings from 1/2012 through 3/2012.
I erased everything and set it to record a show for my wife and this thing can pull in stations that my TV and two set top boxes can't, the tuner in it is really good. I'm really impressed so far!
Stonent is offline
post #11 of 15 Old 02-27-2013, 12:11 AM
gastrof's Avatar
Quoted: 118 Post(s)
Glad to hear it. You two are gonna have such a great time with that machine... smile.gif
By the way, did you find an instruction manual anywhere? The current machines aren't that different. Even one of theirs might do, in a pinch.
gastrof is offline
post #12 of 15 Old 03-02-2013, 11:12 AM - Thread Starter
Stonent's Avatar
Stonent is offline
post #13 of 15 Old 03-22-2013, 03:42 PM
leaseaguest's Avatar
Hey there. If you can't do anything with that in your area, I'll buy it off of you for $20 plus shipping. leaseaguest@hotmail.com
leaseaguest is offline
post #14 of 15 Old 03-23-2013, 11:29 AM - Thread Starter
Stonent's Avatar
No, it works fine. Except for that damned macrovision detection preventing me from converting old tapes to DVD.
Stonent is offline
post #15 of 15 Old 03-23-2013, 11:36 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
A $26 MCM Video Stabilizer should take care of that problem.
wajo is offline
