best opensource downloadable software? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-18-2013, 11:15 AM - Thread Starter
robertkjr3d's Avatar
Quoted: 30 Post(s)
I've been through a bunch of software -- I've downloaded and made a few coasters... Some just don't do what I want... some just crash my Quad core?!... I've uninstalled many (i'm gratefull I don't seem to be infected yet) - many of these also have those hidden agendas, meaning when you install, you need to say no to one or more 3rd party add ons, toolbars or other products.
I want to create DVD Video from a pile of MP4 files with a menu. I'd tell you what I've tried, but I'm not at that machine right now and I've been through a slew of them. At this point I might be willing to pay actual money... but normally its not like buying a Android app, they usually want like $100.
robertkjr3d is offline
post #2 of 5 Old 02-18-2013, 12:54 PM
Westly-C's Avatar
Quoted: 351 Post(s)
Liked: 224
Paid software
VideoRedo Plus-a free trial version is available for you to test. http://www.videoredo.com/en/ProductPlus.htm
Free software
DVD Flick-it's free, produces less elegant menus, but can handle most file formats. http://www.dvdflick.net/features.php
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #3 of 5 Old 02-18-2013, 01:26 PM - Thread Starter
Quoted: 30 Post(s)
tried DVDFlick... I remember that one. After downloading it immediately came up with an error with some ocx file. I think it's not Windows7-64bit friendly. - as quickly as installed... uninstalled...
post #4 of 5 Old 02-18-2013, 01:45 PM
Kelson's Avatar
Quoted: 2008 Post(s)
Liked: 1201
Originally Posted by Westly-C View Post
Paid software
I would second the choice of Video ReDo. I've been using it for quite a while. Yes, it costs $$ but is worth it to have software that works and works without having to install umpteen 3rd party helper apps that have all their own bugs and limitations -- many were never updated to work with anything past Win-XP 32-bit.
VRD will make your DVD's and let you make custom menus. You can edit your clips and split or join them.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 5 Old 02-18-2013, 06:56 PM - Thread Starter
Quoted: 30 Post(s)
Well I've had success with DVDStyler - http://www.dvdstyler.org/en/ However when I tried to add too many video files, and make it a large project. I checked the memory, it was jammed to the roof. And then the program crashed. So I intended to make one disk... But I was able to use the software to make 2 disks from my video files.
