Transfer recorded TV program to External DVD burner? - AVS Forum | Home Theater Discussions And Reviews
Old 03-09-2013, 01:28 PM - Thread Starter
clumb31's Avatar
I have a bunch of TV programs recorded on my HD recorder. It does not have a USB output. Is there any way hook up the recorder directly to burn these programs to an external DVD burner? Do any of them have any other inputs then USB?
I also don't have a TV(?) card in my computer (Windows 8) if it might be necessary to get there first.
(I am not very "techy" on these issues)
clumb31 is offline
Old 03-09-2013, 03:41 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
When you refer to HD Recorder I'm assuming that you mean a DVR provided by a cable or satellite company.
One solution is with a DVD Recorder. Feed a DVR output to the corresponding input on the DVD Recorder. Then play the DVR videos while recording in real time with the DVD Recorder.
A better solution is with a HDD/DVD Recorder such as the Magnavox 5xx series models. Feed a DVR output to the corresponding input on the HDD/DVD Recorder. Then play the DVR videos while recording in real time with the HDD/DVD Recorder's internal hard drive, edit the material if you wish and then high speed dub the material to DVD(s).
Once the DVDs have been recorded they must be finalized.
These procedures produce DVDs in the proper format for playing on all manner of players or computers.
The first post in Wajo's sticky thread is the gateway to a wealth of information concerning the Magnavox HDD/DVD Recorders:
http://www.avsforum.com/t/940657/magnavox-537-535-533-515-513-2160a-2160-2080-philips-3576-3575/0_60#post_12244086
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Old 03-10-2013, 12:20 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
I assume that you are asking about a method that does NOT involve the cumbersome playing back the recorded content in real time and recording it onto a DVD recorder. The answer is, most probably not as these machines are designed specifically to make that operation impossible, or as near impossible as they can. frown.gif
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Old 03-10-2013, 11:07 AM - Thread Starter
clumb31's Avatar
The equipment I have is an Emerson HDD/DVD/VCR recorder. I do not have a DVR, just an ordinary cable box from Comcast that I connect to the Emerson and then from there to the TV with coax cables. The HDD content I recorded cannot be dubbed to the DVD recorder on the Emerson.
clumb31 is offline
Old 03-10-2013, 11:08 AM - Thread Starter
clumb31's Avatar
I would be VERY HAPPY to play back the recorded content to get it on a DVD. Please also see my previous response.
Thank you to all
clumb31 is offline
Old 03-10-2013, 11:30 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
It sounds like you might need a filter between the cable box and your Emerson, like one of those described here?
wajo is offline
Old 03-10-2013, 07:58 PM - Thread Starter
clumb31's Avatar
I think I am going to try(!!!) hooking up a separate DVD recorder and play the HDD content to it. I does seem to record TV shows that the other unit will not. Thanks for all the advice!
clumb31 is offline
Old 03-11-2013, 08:23 PM
Tulpa's Avatar
Liked: 61
Emerson (and by extension, Funai) made an HDD recorder with a VCR and DVD section? And you CAN'T dub to DVD from the hard drive? confused.gif I've never heard of such a beast.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
Old 03-11-2013, 08:52 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Yes, there were Sylvania and Emerson HDD/DVD/VCR combos dating back to 2005/2006. IIRC these could not do a high speed dub to DVD-R or DVD+R DVDs. High speed dubbing was limited to DVD-RWs. Also, IIRC, the Emerson 100 had an 80GB hard drive and the Sylvania 200 had a 160GB hard drive. Here is a thread discussing the Sylvania model:
http://www.avsforum.com/t/777251/sylvania-hdrv200f-3-in-1-dvd-vcr-combo-with-160gb-digital-recorder/0_60
This November 2009 post describes dubbing limitations of these combo recorders:
http://www.avsforum.com/t/777251/sylvania-hdrv200f-3-in-1-dvd-vcr-combo-with-160gb-digital-recorder/120_60#post_17495840
This is an interesting thread discussing HDD recorders back in 2006:
http://www.avsforum.com/t/665002/list-all-the-2006-hdd-based-models/0_60
DigaDo is offline
Old 03-11-2013, 09:40 PM
Tulpa's Avatar
Liked: 61
Interesting.
Tulpa is offline
Old 03-12-2013, 09:15 AM - Thread Starter
clumb31's Avatar
Well, a very strange thing has happened to my Emerson!. YES, I WAS able to dub a few years ago. NOW, I can't. I can't even record TV shows on DVD now when I used to be able to in the past I also get "copy protected" warning now and can't record certain movies. I have another DVD recorder and I can record to DVD on that - so something has happened to the Emerson and I would like to find a way to get the HDD content on it to a DVD - hence my idea of hooking up the other recorder but haven't had time yet to see if it can be done.
clumb31 is offline
Old 03-12-2013, 11:50 AM
Quoted: 111 Post(s)
Liked: 86
I expect that there is nothing changed about your Emerson. In the interval betwen when you know you could make recording, and now, it's likely that Comcast has enabled copy protection on every channel that they can, and your Emerson is responding to these content protection signals. Some recorders are more prone to honoring these signals than others. Yours may be particularly sensitive. I would read Wajo's reply about gettng a video filter to remove the copy inhibit signal which will allow you to record.
Luke
Old 03-12-2013, 12:13 PM - Thread Starter
clumb31's Avatar
Thank you for that explanation. I am sure that is the problem with making a new recording. However, I have programs recorded some time go on the HDD and can't dub to a new DVD which I was able to do in the past. I am wondering if there is a separate Laser in the Emerson that is not working. I CAN play existing DVDS and I CAN record on the HDD portion.
clumb31 is offline
Old 03-12-2013, 04:30 PM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
What kind of media are you trying to dub to? It's possible the media you use to use was complaint for CP'd programs but your new media is not...
jjeff is offline
Old 03-12-2013, 04:53 PM
profhat's Avatar
Let's try this: unplug your Crapcast box from the Emerson, and record for a minute to your HDD, then try to dub that tittle to DVD.
If you can make the dub, the issue is due to the friendly Greedywood CP flag .
profhat is offline
Old 03-13-2013, 09:08 AM - Thread Starter
clumb31's Avatar
Perhaps I have confused you and used the wrong terminology.The Emerson IS what I have been calling the HDD. As I understand things , it has a hard drive that has been recording the content. Should I have given it a different name?
The content recorded on the Emerson hard drive was such things as PBS specials. It came from the cable box, via coax- this is the only way I can get TV
clumb31 is offline
Old 03-13-2013, 10:36 AM
Westly-C's Avatar
Quoted: 322 Post(s)
Liked: 200
In the case of a unit with built in hard drive, brand name and HDD are synonymous in his reply. We need to drill down whether your Emerson is being victimized by errant copy protection signals from the cable box, or whether the symptoms are due to the unit malfunctioning.
So, we need you to connect an old vcr or another dvd player to the Emerson and record something (an old, non copy protected, recording made before these issues cropped up) to the HDD (hard disc drive) and try dubbing it to a blank dvd, If you aree able to dub successfully, that tells us that your Emerson is still in good working order, and you are indeed, getting hit wil CP from Comcrap.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
Old 03-14-2013, 12:08 PM - Thread Starter
clumb31's Avatar
Thanks, I tried that and no go. See attached photo.To recapitulate, I have another DVD recorder also connected to Comcast and I can record shows from that whereas I cannot record on the DVD portion of the Emerson but I can on the HDD portion.
clumb31 is offline
Old 03-17-2013, 09:02 AM
profhat's Avatar
My friend, I guess the issue is in the DVD-Burner (cables, circuits, laser diode, etc) Before to buy a replace, try a good DVD cleaner.
profhat is offline
Old 03-17-2013, 12:14 PM - Thread Starter
clumb31's Avatar
Thanks for the suggestions.
I will be unable to view further posts on this for about three weeks
clumb31 is offline
