Can I finalize DVD -R from my toshiba RD-XS24 on a PC?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-16-2013, 09:43 AM - Thread Starter
josealejandrom's Avatar
DVD recorder is Toshiba RD-XS24SG
Used it for years to record home videos from my sony mini-dv camara to DVD -R (Verbatim DVD -R, 4,7GB, 16x)
Unfinalized DVD apear as "blank" on PC
DVDdecrypter can not copy
Code:
Dvd Decrypter:
HL-DT-ST DVDRAM GH22NS50 TN03 (ATA)
Current Profile: DVD-R
Disc Information:
Status: Incomplete
Erasable: No
Free Sectors: 18.416
Free Space: 37.715.968 bytes
Free Time: 04:07:41 (MM:SS:FF)
Pre-recorded Information:
Manufacturer ID: MCC 03RG20
Recording Management Area Information:
TOSHIBA 57S1T16416 DVDRAM DAV-WR412
Physical Format Information (Last Recorded):
Disc ID: 0@P-!-00
Book Type: DVD-R
Part Version: 5
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196.608
Last Physical Sector of Data Area: 2.495.103
Last Physical Sector in Layer 0: 0
DVD Decrypter can not extract dvd contents ("disk is empty")
Using toshiba´s menu I finilized 20 DVD -R, only 2 of them can be read on mi pc
Is there another way to finalize these DVD -R, perhaps on a PC with some program....
PD: sorry about my english, I am spanish
josealejandrom is offline
post #2 of 9 Old 03-16-2013, 10:41 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
You might try ImgBurn or Nero to finalize. Otherwise you could possibly recover the data using ISOPuzzle or ISOBuster.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 9 Old 03-16-2013, 12:46 PM - Thread Starter
thank you but
Nero didn´t work (close VR disk-->" nonspecific recorder error")
can´t find menu to close or finalize disk in imgburn
iso puzzle says "disk is empty"
Any sugestions will be wellcome, I have 120 DVD -R to "fix"¡¡
post #4 of 9 Old 03-16-2013, 01:03 PM - Thread Starter
nod antivirus ivirus doesn´t let me download try version of isobuster ( http://www.isobuster.com/download.php )
(complains about win32 toolbar conduit aplication....)
My toshiba RD-XS24 is quite old
A friend has similar recorders ( sony and samsung, not toshiba)
I wonder if I could try to finalize one dvd in them (just in case...)
post #5 of 9 Old 03-16-2013, 01:20 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Possibly an optional software that comes with it? Here's close a disc in ImgBurn:
olyteddy is offline
post #6 of 9 Old 03-16-2013, 04:01 PM
Super Eye's Avatar
Quoted: 46 Post(s)
Liked: 34
Unfinalized DVD apear as "blank" on PC … Is there another way to finalize these DVD -R, perhaps on a PC with some program…
Regarding Nero - instead of using “Burning Rom” try using “Nero Recode”. That works for me with my unfinalized Sony RDR-HX780 recorded discs.
With my situation Nero Recode does not recode the files but Nero would copy the disc bit-for-bit and ask me to insert a new disc and Nero would burn and finalize the program on the new disc. The problem with this option is that you will have to replace each disc with a new disc.
See this thread.
http://www.avsforum.com/t/1409286/finalizing-a-pio-sony-disc-with-nero
See this thread for others that used Nero successfully.
http://www.avsforum.com/t/981951/finalizing-dvds-with-a-different-dvd-recorder
Another possibility is to try the “finalize option” with Nero Vision as seen in my included image. This option would not work with my Sony RDR-HX780 unfinalized discs but its worth a try with your Toshiba discs.
Super Eye is offline
post #7 of 9 Old 03-17-2013, 08:55 AM
profhat's Avatar
1st you need to check if there's something to "fix" with IsoBuster.
profhat is offline
post #8 of 9 Old 03-17-2013, 08:55 AM
profhat's Avatar
profhat is offline
post #9 of 9 Old 03-18-2013, 01:13 PM - Thread Starter
thanks all
imgburn can not close disk (or session) it gives an error message
but I can not extract files with unregistered (try out) version¡¡
(I can extract a track as an iso archive)
looking for a nero version that includes recode. or vision .. (I have only CD versions that comes with burner...)
is there a try out version?
