Pan.EH-55,59--Tivo--Netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-18-2013, 01:09 PM - Thread Starter
jasta's Avatar
If I play Netflix on my Tivo, can I record it to my Pan. in some way?
jasta is offline
post #2 of 10 Old 03-18-2013, 02:14 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Unless it has CP(in which case you'd need a filter) you should be able to record from the Tivos line output(composite or S-video) to your Panasonics line input. The cheapest filter in this case would be a component to S-video converter, <$40 for a Lenkeng clone from Monoprice.
jjeff is offline
post #3 of 10 Old 03-20-2013, 06:04 AM - Thread Starter
jasta's Avatar
jasta is offline
post #4 of 10 Old 03-20-2013, 06:04 AM - Thread Starter
jasta's Avatar
jasta is offline
post #5 of 10 Old 04-12-2013, 01:40 AM - Thread Starter
jasta's Avatar
Can I do the the same thing with the line inputs on a computer?
jasta is offline
post #6 of 10 Old 04-12-2013, 06:49 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
You would need to make the PC into a video recorder which means adding a video capture device like a Hauppauge 1215 or Colossus. The capture device has the AV inputs. The proviso that jjeff stated about copy protection and the need to have an extra device to bypass it still holds.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7 of 10 Old 04-13-2013, 03:43 AM - Thread Starter
jasta's Avatar
Thanks. Netflix installs something called Silverlight on your computer, which blocks you from recording the streaming video. Would that also block the Panasonic DVD recorder?
jasta is offline
post #8 of 10 Old 04-13-2013, 10:19 AM
Kelson's Avatar
Liked: 1147
Don't know.
- kelson h
Kelson is offline
post #9 of 10 Old 04-13-2013, 12:44 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
I don't know for sure either but I doubt you'd have a problem, if on the chance you did get a CP warning a video filter would easily take care of it(although I doubt it would be CP'd and even if it was I doubt the CP would make it through a VGA to S-video converter that would be required to record it on your Panasonic).
jjeff is offline
post #10 of 10 Old 06-27-2013, 12:35 PM - Thread Starter
jasta's Avatar
Thanks. Do you know of any computers that already have a video capture device? If so, which ones? If not, how do you install such a device?
jasta is offline
