Panasonic Ag 1980 tbc question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-22-2013, 06:28 PM - Thread Starter
Johntomk's Avatar
I am transferring old vhs-c tapes to my computer using a canopus advc-110 and panasonic ag1980. I have two questions I have not been able to find clear answers for.
1. Should the TBC be used on all tapes the entire time, or should it only be used on problematic tapes that drop frames?
2. How exactly does the picture sharpening work? From what I understand it cannot be turned off. When the slider is at soft is it performing the least amount of sharpening, or is it artificially softening the image? I want the least amount of artificial sharpening or softening as possible.
Thank you.
Johntomk is offline
