ImgBurn Downloads and Alternate Programs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-23-2013, 08:45 AM - Thread Starter
Jim Mohundro's Avatar
Quoted: 12 Post(s)
For several years I had used the ImgBurn freeware to copy non-copy protected DVDs. With the purchase of a new desktop PC of course my ImgBurn application has gone away and I'd be happy to download it again--except that, when I go to the ImgBurn site, there appear to be several download options. none of which are provided by ImgBurn. I always wonder if these various download options are safe, i.e., I don't want to be downloading a monster virus inadvertently.
1) Should I be looking at a reliable commercial program? Several years ago I used some fairly comprehensive Nero application but it was cranky and hung up from time to time. When I purchased a new computer, the manufacturer suggested ImgBurn and it had served me well up to this time. I'm just a little nervous in downloading from ImgBurn's web site but not from ImgBurn itself, so.
2) Is there any way to identify safe downloading utilities?
Jim Mohundro is offline
post #2 of 6 Old 03-23-2013, 08:59 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
Imageburn's mirrors are reliable. I've contacted the author about several things with the program, and I have no problems with using any of those mirrors. Having said that, the one I would trust the most is www.videohelp.com. You can download it directly from their site, and I would rely on it as reputable and not something that is going to infect your computer.
It is still the best program by far to burn discs.
SMK
ClearToLand likes this.
RoyGBiv is offline
post #3 of 6 Old 03-23-2013, 09:03 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
download.cnet.com has been good for me and somewhere they used to say their SW has been virus-tested before being posted?
wajo is offline
post #4 of 6 Old 03-23-2013, 11:01 AM
Kelson's Avatar
Quoted: 1951 Post(s)
Liked: 1146
I would second Videohelp.com. It is my primary site for acquiring software and utilities. I've never had a problem and if in doubt you can always have your virus software scan the download file (if it doesn't do so automatically).
Also a good and reputable site that I would second -- until recently. I have downloaded much from them over the years and never had anything undesired sneak through. But now it seems they want you to install a stub installer in order to download software. Ad-supported, no less. I refuse to do that.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 6 Old 03-24-2013, 07:01 PM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 31
SUBJECT: Reputable Download Sites...
  • Quote:
    Imageburn's mirrors are reliable. I've contacted the author about several things with the program, and I have no problems with using any of those mirrors. Having said that, the one I would trust the most is www.videohelp.com. You can download it directly from their site, and I would rely on it as reputable and not something that is going to infect your computer...
  • Quote:
    Originally Posted by Kelson View Post
    I would second Videohelp.com. It is my primary site for acquiring software and utilities. I've never had a problem and if in doubt you can always have your virus software scan the download file (if it doesn't do so automatically)...
    ...Also a good and reputable site that I would second -- until recently. I have downloaded much from them over the years and never had anything undesired sneak through. But now it seems they want you to install a stub installer in order to download software. Ad-supported, no less. I refuse to do that.
I've been using VCDHelp.Com, now Videohelp.Com, for almost a decade without problems. VCDHelp and Doom9 were my "Go To" sites for info. You'll find *MANY* useful programs at both sites.
Download.Com / CNET.Com *WAS* a good site *MANY YEARS* ago, but since they added the intermediary download LINK at least a couple of years ago, I've avoided them.
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #6 of 6 Old 03-24-2013, 11:33 PM - Thread Starter
Quoted: 12 Post(s)
Thanks for helping me with my question. I used vide help.com and it went quite smoothly.
