DVD recorder And HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-25-2013, 09:28 PM - Thread Starter
chargersrool's Avatar
Im looking for a DVD recorder that will record my favorite programs from TWC like speed channel, food, disc, hist, etc. The main thing is if there is a DVD recorder that will allow you to download to a external hard drive or store them on it instead of using a disc. (Dont want to spend $100s of dollars on discs.)
Heres what i want to do:
Want to use-
http://www.costco.com/Seagate-Backup-Plus-3-TB-Desktop-Drive.product.100007783.html
with
http://www.amazon.com/Toshiba-DR430-Upconversion-Progressive-Recorder/dp/B0065NA1K0/ref=sr_1_8?s=electronics&ie=UTF8&qid=1364266331&sr=1-8&keywords=dvd+recorder
Or if anyone can find any better deals on DVD recorders just show the link and give your review of it if you own one.
-On the amazon link it says the DVD recorder doesnt have a tuner, what would a tuner be necessary for?
chargersrool is offline
post #2 of 4 Old 03-25-2013, 09:48 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Originally Posted by chargersrool View Post
Want to use-
http://www.costco.com/Seagate-Backup-Plu…
with
http://www.amazon.com/Toshiba-DR430-Upco…
If you have a TWC converter box or DVR you don't necessarily need a DVD recorder with a tuner. The TWC converter box or DVR tunes the "channels." The Toshiba DR430 is a "garden-variety" DVD recorder that records from line inputs, those being the S-Video or yellow composite video plus white and red audio inputs. I have a Toshiba DR410 (a 2008 version of the DR430) but it's used only to play DVDs with the family viewing TV.
The "better deal" is a Magnavox 5xx series HDD/DVD Recorder. I have seven of these (and earlier versions) set up for daily use.
The first post in Wajo's sticky thread is the gateway to a wealth of information concerning Magnavox HDD/DVD Recorders:
http://www.avsforum.com/t/940657/magnavox-537-535-533-515-513-2160a-2160-2080-philips-3576-3575/0_60#post_12244086
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #3 of 4 Old 03-25-2013, 10:56 PM
Westly-C's Avatar
Quoted: 322 Post(s)
Liked: 202
Blank discs-good quality ones, won't cost you $100s of dollars either...wink.gif
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #4 of 4 Old 03-26-2013, 10:29 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Does not exist. There is no DVD recorder on the market that has the capability of off-loading its content other than by burning a disc. You can then use a PC to read the disc and transfer the contents to an external HDD. If you want to record and go straight to an external disk, get a PC tuner like Hauppauge, Ceton or Silicon Dust and use your PC to do the recording.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
