Need new usb composite video capture card that can record macrovision content. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2013, 02:42 PM - Thread Starter
techspark's Avatar
Hi, I m looking to buy a new usb capture card that has the following features ;
1. Composite yellow video input.
2. Records macrovision protected content.
3. Can record pal video 576i ( in 50fps if possible)
4. Under $120
5. Usb 2.0 only as need it for laptop.
I was looking at hauppauge usb live 2 but it cannot record macrovision protected content. I dont want to buy hauppauge hd pvr as i just need composite video recording and dont want to spend excess of $150.
All suggestions are welcomed , thank you!
techspark is offline
post #2 of 4 Old 04-18-2013, 02:49 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The $26 MCM filter described here should do the trick, assuming you have a YWR RCA source feeding your current card?
Edit: Oops, doesn't do PAL AFAIK! Maybe one of the other filters in that help file?
wajo is offline
post #3 of 4 Old 05-08-2013, 10:29 PM - Thread Starter
techspark's Avatar
Thanks - but i prefer a proper capture card that comes with the cables and software.
Any other suggestions guys ??
post #4 of 4 Old 05-09-2013, 08:33 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
I'm probably stating the obvious: The purpose of Macrovision is to prevent recording (copying) the source; all legal recording devices support it.
So unless you can find some sort of gray-market chinese device, you are going to need a video filter between your source and any proper capture card.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
