DMR ES30V FUSE OK BUT NOTHING COMES ON - AVS Forum | Home Theater Discussions And Reviews
Old 04-21-2013, 09:04 AM - Thread Starter
MOTTO's Avatar
HAVE POWER IN AND OUT OF FUSE. NO CAPS SEEM LOOK BAD. NO PRINT SO WHAT TO
CHECK NEXT. ANY ADVICE I WOULD APPRECIATE .THANKS
MOTTO is offline
Old 04-22-2013, 11:51 AM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
First, turn the Caps Lock off before posting/responding in this Forum.
While "nothing comes on" might be an apt starting place for hands-on diagnosis, it doesn't provide enough detail for long-distance diagnostic purposes.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Old 04-22-2013, 05:50 PM - Thread Starter
MOTTO's Avatar
thanks for response. the player is completely dead. i checked fuse it checks ok i looked at all
capacitors non are leaking and non are swollen. i was wondering what to check next . i took the
2 capacitors that are 100uf@ 250v out and they checked ok .
MOTTO is offline
Old 04-23-2013, 12:19 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
it definitely sounds like something in the power supply if the unit is completely dead. I would suggest you send a PM to MICKINCT about it. That is a private message. You access the PM function by going to the very top of the AVS web page and there will be a link called "new messages". Click on it, then click on compose new and send a message to user MICKINCT.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
