Panasonic DMR-ES35V > dirty VHS head > cleaning ? - AVS Forum | Home Theater Discussions And Reviews
Old 05-22-2013, 05:19 AM - Thread Starter
carambaXXX's Avatar
There must be a specialist in this forum who solved that problem already. The VHS-Cassettes must have smeared dirt on the "reading head" - the image quality is less than poor ! How can I clean that device ? Thanks a lot for your answer in advance !
carambaXXX is offline
Old 05-22-2013, 09:14 AM
Westly-C's Avatar
Quoted: 329 Post(s)
Liked: 205
Have you tried using a head cleaning tape? They may be hard to find, but a wet head cleaning tape-they come with a bottle of cleaning solution that you place a few drops in an opening, and then place in the vcr and playback for a minute.
Though your description of the image quality sounds like it may be beyond a simple remedy like this, but it's worth a try. Perhaps you could find a local tv/electronics repair shop and call and ask if they still service vcrs.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
