Pioneer DVR-640H HDD Error - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-23-2013, 05:29 PM - Thread Starter
SilentRunning's Avatar
I recently acquired a Pioneer DVR-640H without a Hard Drive.After installing a HDD in the unit and Following the prescribed procedure with Service Remote,CPRM Code Number and Pioneer Data Disc (I've done this successfully a few times with other Pioneers) I keep getting Hard Drive Information is Incorrect.Anybody have any ideas on what I can do next? Is it possible that the CPRM on the back of the unit is wrong?
SilentRunning is offline
post #2 of 9 Old 05-24-2013, 11:38 AM
CitiBear's Avatar
Quoted: 101 Post(s)
Liked: 91
This issue is fairly common when servicing the 550/650, occasional with the 560/660, and rare with the 540-543-640. The cure involves some degree of luck and voodoo: let the unit sit overnight, try the process again, if it fails wait another night, try again, etc, until eventually it "takes." I've never seen an incorrect CRPM sticker on the back panel of a Pioneer: it is possible, but doubtful. More likely your 640 is just being stubborn and resistant to the HDD replacement, as they sometimes are.
You might consider a couple of points that are easy to overlook. First is did you perform the Initialize HDD step? Using the normal remote, go into the Home Menu>Initial Setup>Disc Setup screen, and check to see if the option "Initialize HDD" is shown (the recorder only makes this visible when it needs to be done). If Initialize HDD is available, that means the HDD needs to be formatted to clear the "HDD Is Incorrect" warning, so tell the unit to initialize. If you don't see the Initialize HDD option, something else is causing the error, and you'll need to troubleshoot further.
The HDD itself: where did it come from? Is it new, or taken from a PC? Individual Pioneer recorders have a varying tolerance for repurposed or pre-formatted HDDs: some accept them and initialize them with the Pioneer OS with no hiccups, while others choke on anything but a completely erased HDD. Try attaching the HDD to a PC and use a Linux, Mac or Windows utility to completely erase it: under the format options, choose "none" (no file system of any kind, no partitions). Then put it back in your 640 and try the CPRM match again. Also check the location or presence/absence of the tiny termination plug on the rear of the HDD: some Pioneers work better with no plug, others work better with it in the Cable Select position. Examination of the original HDD is often helpful on this point: unfortunately you don't have it, so may need to experiment.
Another thing to watch out for is the service dvd: make sure you have the correct one for the 640. Like the 550/650 and 560/660, the 640 requires a "Type 2" service i.d. data disc. The version most commonly circulated online is the "Type 1" version GGV1179, designed for the earlier 510 and 520 series. This will not work correctly in the 640, which needs the later GGV1305 or GGV1321 disc. Check to be sure the unit displays "ROM Write OK!" onscreen after running the service DVD, sometimes it flashes "ROM Write NG!" very quickly and you miss it, assuming all went well.
Finally, the last step in the CPRM process is very twitchy with some units. Most are not that particular about the sequence, others are extremely picky and will result in "HDD Err" if it isn't done EXACTLY as follows: after the unit displays "ROM Write OK!" on your TV, remove the service disc from the tray but DO NOT close the tray. Press CLEAR on the service remote, then press the power button on the recorder front panel. The tray will close automatically and the unit will power off. Wait a couple minutes, then turn it back on. It should boot normally with no error display.
CitiBear is offline
post #3 of 9 Old 05-24-2013, 06:00 PM - Thread Starter
Thank you Citibear for your reply.I just noticed that I am unable to Access the Home Menu with the Remote so I am unable to Initialize the HDD like I have done every time I have upgraded a Pioneer in the past.Perhaps there is another problem here.I am using an old hard drive that's been sitting unused for a very long time,I'd prefer a new one but the 640 uses IDE Drives and I don't think those types have been made for years.Whenever I've installed a HDD in a Pioneer I always Format to FAT32 then Delete the Partition with Acronis Disc Director and have never had a problem before.I always set Jumpers to Cable Select and I am using Data Disc GGV1321 which I believe is Type 2 .I am getting the "ROM Write OK" prompt ,then I remove the disc,press Clear then Power Off without closing the tray.However I generally Power ON again almost immediately.I'll try waiting a few mins next time I attempt this probably tomorrow.I'm now thinking not being able to get the Home Menu means something else is amiss.
post #4 of 9 Old 05-25-2013, 08:21 AM - Thread Starter
Amazingly this morning the hard drive was accepted and is now working perfectly.I did everything the same as before except this time I waited about 5 Mins after Powering Off before Powering On again.Thanks so much for your help Citibear.I have a question regarding the aluminum tape that runs from the HDD to the base it's attached to on many of the Pioneer DVRs including this model.Since I bought this recorder without the hard drive it also doesn't have the 2 strips of aluminum tape.Exactly what function does the tape serve and how important is it for me to put it on this 640 model?
post #5 of 9 Old 05-26-2013, 06:00 PM
CitiBear's Avatar
Quoted: 101 Post(s)
Liked: 91
The aluminum tape is applied for grounding/shielding purposes: the unit will function without it as long as you re-apply the foam blocks that keep the cabinet cover from touching the internals. It would still be better to buy a roll of the tape and re-apply it as done on the original HDD, however: these recorders can be very sensitive to the slightest HDD glitch, including spurious electrical noise or poor grounding. Since you say this particular 640 came to you without the original HDD, you likely didn't get the foam cabinet-standoff blocks either: at a minimum, you should not connect the unit to power without those blocks. It is remarkably easy to short out and destroy a recorder motherboard by cabinet pressure on one of the internal metallic parts (HDD, DVD, PSU, etc).
Best practice would be to study one of your other Pioneers and apply fresh grounding tape and spacer blocks to the repaired unit to match.
CitiBear is offline
post #6 of 9 Old 05-27-2013, 11:29 AM - Thread Starter
Citibear thanks for the heads up on the tape and foam blocks.Fortunately the foam blocks are still on the flat ribbon that connects from the main board to the adaptor board that connects to the Hard Drive.I definitely will get the aluminum tape to ground it.I did a test recording last night and I swear the picture quality is better on the 640 than the 540 that I still use.
post #7 of 9 Old 11-01-2013, 07:03 AM
dmata10's Avatar
Where did you get your GGV1321 Data Disc, Silent Running?  My 450H just started posting an error with the HD message a few days ago after we lost power one night.
Before that it was working great. I bought the unit new in 2007.  I found a service remote on eBay so now allI need is the Data Disc.  Thanks.
dmata10 is offline
post #8 of 9 Old 11-03-2013, 07:14 PM
ngohit's Avatar
Knock on wood, I do not need the information in this thread right now, but just in case I do some day, it is getting bookmarked. CitiBear: The time you took to share information on how to replace the HDD is definitely appreciated.
Maybe I should look for a service remove and necessary disks before I need the, while they might be easier to find than later.
Although I mostly use my H640 ad H650 these days (in the living room), my original, 420H purchased after someone here said Costco was selling their inventory is still connected (in a bedroom) and works.
ngohit is offline
post #9 of 9 Old 11-04-2013, 02:20 PM
CitiBear's Avatar
Quoted: 101 Post(s)
Liked: 91
Originally Posted by dmata10 View Post
Where did you get your GGV1321 Data Disc [...]
As mentioned by myself and other Pioneer owners in many AVS threads, the key reference site for all things related to Pioneer DVD/HDD recorders is PioneerFaq. If you go to this page at PioneerFaq, you will find links to hard drive replacement instructions for the various model series on the left hand blue column. If you need a Service I.D. Data Disc, make a small PayPal donation to supportATpioneerfaqDOTinfo, with a note requesting which disc you want, and you'll be directed to a clean download link. Donations defray the expenses incurred keeping the site hosted online, and are much appreciated. There were endless versions of the service disc covering dozens of international Pioneer model variants. But since Pioneer stopped making recorders in 2008, it really boils down to just the final versions of the Type 1 and Type 2 service discs.
Models in the x100, x10, x20 and x30 series need a Type 1 disc, the most reliable version being GGV1256. The GGV1302 was the last actual Type 1 disc, but seems impossible to get and offers no real benefit over the GGV1256. The very old GGV1179 should be avoided in favor of the GGV1256. Especially avoid random torrent links you might find to the GGV1179: these are often corrupt or partial disc images. Models in the x40, x50, x60 and LX series require a Type 2 service disc, the last of which was the GGV1321.
The service remote can be difficult or expensive to obtain, depending on the country you live in and which version you buy. The original Pioneer service remotes are long out of production and impossible to find, but generic "clones" are still available in North America. The one that I've used for many years is the Pioneer GGF1381 clone available here for $51.95. Several years after I bought it, Sony began offering their J-609-0-203-A clone, which was bargain priced at under $20. Unfortunately Sony stopped selling it in 2011, but a nice generic clone is available here for $21.95. There is no functional difference between these clones, if the cheaper one had been available when I was looking I would have bought it.
CitiBear is offline
