Panasonic DMR-EA18K Issue--Status staying up after Pressing Record - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-20-2013, 03:03 PM - Thread Starter
computerman3's Avatar
Hi All
Some Reason when using this Recorder, the Status little window stays up in the right corner, hitting status makes it go away, but is that gonna show up on the final recording if I manually click status, then take it off that way? I believe the machine has the latest firmwire as far as I know, don't use this machine all that much, but decided to today, to save wear and tear on my Philips model for a change.
Thank you all in advance
computerman3 is offline
post #2 of 4 Old 06-20-2013, 03:32 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
The status messages don't show up in recordings.
Status Messages may be deactivated:
Choose whether to show status messages automatically or not.
Access the Setup Menu, select “Display”, then select “Status Messages”, then select “Automatic” or “Off.”
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #3 of 4 Old 06-20-2013, 03:51 PM - Thread Starter
Oh Thank you for that info, will check that out once this recording Is over with
Really Appreciate the quick reply
post #4 of 4 Old 06-20-2013, 03:57 PM
jjeff's Avatar
Quoted: 768 Post(s)
Liked: 268
I also disable my automatic status messages, the EZ/EA models have kind of a bug where they turn on and off at random times and for no apparent reason, even disabled you can bring it up by just pushing the status button.
jjeff is online now
Panasonic Dmr Ea18k Tunerless 1080p Upconverting Dvd Recorder
