DVR with Digital Tuner - AVS Forum | Home Theater Discussions And Reviews
Old 07-15-2013, 05:07 AM - Thread Starter
DVORASNELL's Avatar
I am really new to the DVR world. Does the DVR with Digital Tuner function like a "TiVo:? Can you record one show and watch another? Can you program for future, based on the TV codes (those little numbers that they say will anchor recording)?
As I said I am really new at this
DVORASNELL is offline
Old 07-15-2013, 06:04 AM
Quoted: 863 Post(s)
Liked: 349
1 - Does the DVR with Digital Tuner function like a "TiVo:?
2 - Can you record one show and watch another?
3 - Can you program for future, based on the TV codes (those little numbers that they say will anchor recording)?
1 - A TiVo records and plays recorded programs. By definition the answer is YES, but with a million exceptions.
2 - If the DVR has a dual tuner. You can usually record one and watch a recording.
3 - Not to my knowledge.
This is a Standard Definition forum. Try searching the HDTV Recorders forum for other information. Try here:
http://www.avsforum.com/t/1460149/updated-list-of-consumer-available-dvrs-in-the-us/0_50
JoeKustra is online now
Old 07-15-2013, 08:10 AM
Tulpa's Avatar
Liked: 61
Are you talking about the Magnavox DVD recorder with a hard drive? If so, the answer is "sort of, depending on what you want to do." It can record unattended to its hard drive, and do stuff like pause live TV (chase play.)
Maybe, depending on your setup and TV provider (if you have one.) You will need a second tuner, such as the one in your TV. But we need more info on how you're currently getting TV (antenna, satellite, cable, etc.)
There are a lot of variables depending on what you have and want.
Are you talking the old VCR+ codes? Or something like a cable box's guide? No, those don't work with the Magnavox.
If on the otherhand you're talking about a cable company's DVR (Digital Video Recorder) and not a DVD recorder, then yes, it'll work like a TiVo, though it won't have as many extra features.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
