DVD door won't open - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-17-2013, 03:11 PM - Thread Starter
Art22's Avatar
Brand new out of the box Toshiba DVR 620 - DVD door/platter won't open. Is it faulty or did I not do something else first?
Art22 is offline
post #2 of 7 Old 07-17-2013, 03:18 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
DVD tray won't open until you do all the initial setup procedures... set clock, set OSD Language (Display menu), and do an auto channel scan (Channel menu).
wajo is offline
post #3 of 7 Old 07-18-2013, 08:05 AM - Thread Starter
Art22's Avatar
I did the initial setup procedures, but there was no Channel Scan / Channel menu that I could find.
Art22 is offline
post #4 of 7 Old 07-18-2013, 08:49 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Oops, I forgot that the 620 doesn't have a tuner, it's for "line-in" recording from an external box, like a cable or sat STB, VCR, etc.
wajo is offline
post #5 of 7 Old 07-18-2013, 11:18 AM - Thread Starter
Art22's Avatar
Hi Wajo,
Not sure what your last reply was indicating. I'm far from trying to record TV broadcasts, just getting started with this new machine. I've explored all the setup menus and enterred the date and time, etc. Pushing the "open" button (on the front panel or the remote) doesn't seem to work. The hinged door moves slightly (just enough so see it move), but that's all. I'm on the verge of returning this box unless someone can tell me I'm doing something wrong. Thanks!
Art22 is offline
post #6 of 7 Old 07-18-2013, 12:03 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
You said you couldn't find a channel scan menu and I said, oops, that's right, it doesn't have a tuner to scan channels for.
If the tray moves at all but stops, that does indicate a problem. It could be a simple fix but might require opening the lid, which would void your warranty. A return seem to be the best option.
wajo is offline
post #7 of 7 Old 07-18-2013, 06:00 PM - Thread Starter
Art22's Avatar
Thanks Wajo - that's what I'm going to do.
Art22 is offline
Toshiba Dvr620 Dvd Recorder Vcr Combo
