HELP! Can't preset channels now on my Magnavox NB820 DVD Recorder / DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-01-2013, 03:06 PM - Thread Starter
CBK9001's Avatar
Hi. I'm a newbie here and I need some help.
A couple of weeks ago, during a thunderstorm, my Magnavox NB820 DVD recorder got zapped.
At first, it was non-functional, save for the clock display on the front. I unplugged the unit for a day, plugged it back in and to my relief, the DVD player was fully functional and my recorded TV programs were still on the hard drive and watchable.
However, I have not been able to preset channels on the unit since then. The manual was no help and I want to exhaust all possiblities to get the channels preset before throwing up my hands and buying a new unit.
Is there something I can do to get the channels preset so I can record shows again?eek.gif
Any help is much appreciated,
Chris
CBK9001 is offline
post #2 of 17 Old 08-01-2013, 03:19 PM
Guest
Quoted: 38 Post(s)
Liked: 198
Do a Soft Reset, as described here, and see if that helps.
7558037 is offline
post #3 of 17 Old 08-01-2013, 03:51 PM - Thread Starter
CBK9001's Avatar
I will give it a try. Thanks.
CBK9001 is offline
post #4 of 17 Old 08-01-2013, 03:59 PM - Thread Starter
CBK9001's Avatar
I believe a "hard reset" may be a better option, as my DVD and recorded program functions work fine. But I do not see a "skip" button on my magnavox remote. There is a "V skip" button...
CBK9001 is offline
post #5 of 17 Old 08-01-2013, 05:40 PM
Guest
Quoted: 38 Post(s)
Liked: 198
SKIP or V-SKIP button, same thing.
7558037 is offline
post #6 of 17 Old 08-01-2013, 06:06 PM - Thread Starter
CBK9001's Avatar
Do I press the buttons in sequence once powered up, or do I have to hold them all down at the same time?
CBK9001 is offline
post #7 of 17 Old 08-01-2013, 06:11 PM
Guest
Quoted: 38 Post(s)
Liked: 198
Press in sequence, all within 3 sec
7558037 is offline
post #8 of 17 Old 08-02-2013, 06:13 PM - Thread Starter
CBK9001's Avatar
Did the hard reset per the instructions. Unit is same as before: DVD and recorded programs work fine, but I can't get it to preset the channels. Ran through the preset sequence and...nada.
Is there anything else I can try or am I going to have to get a new recorder?
CBK9001 is offline
post #9 of 17 Old 08-02-2013, 06:33 PM
Guest
Quoted: 38 Post(s)
Liked: 198
As a last resort, disconnect both coax cables from the recorder and do an Auto Channel Preset with coax off to clear any channel memory or stray lightning bolts.
Then, reconnect coax cables and do a normal Auto Channel Preset.
7558037 is offline
post #10 of 17 Old 08-03-2013, 05:37 AM
Guest
Quoted: 38 Post(s)
Liked: 198
If no joy from the Auto Channel Presets described in my post above, which you should try first, the ultimate resort would be to reload the FW, but only if your unit is a 513 model. The "NB820" you mentioned is the model # of the OEM remote for the 2160, 2160A and 513... you haven't mentioned the model # of your recorder yet.
The FW instructions for the 513 are here.
That FW procedure will allow you to upload the 02C FW for the tuner, which *could* have been zapped by the lightning strike, as well as the appropriate BE FW for your specific recorder model and its current BE FW version, I'd upload them both.
7558037 is offline
post #11 of 17 Old 08-03-2013, 06:56 AM - Thread Starter
CBK9001's Avatar
Thanks. I'll look into that. Appreciate all your input.
CBK9001 is offline
post #12 of 17 Old 08-03-2013, 06:59 AM
Guest
Quoted: 38 Post(s)
Liked: 198
What your unit's model number?
7558037 is offline
post #13 of 17 Old 08-20-2013, 02:37 PM - Thread Starter
CBK9001's Avatar
H2160MW9
CBK9001 is offline
post #14 of 17 Old 08-20-2013, 03:17 PM
Guest
Quoted: 38 Post(s)
Liked: 198
H2160MW9
There are no FW updates for the 2160. Make sure you have a 2160 and not a 2160A... 2160 will have mfg date in 2008, 2160A in 2009, on back tag of unit.
If you can't tell for some reason, you'll have to check the FW Versions installed and compare to the 2160/2160A "Model" dates as described here.
2160 Model is E2M01UD
2160A Model is E2S00UD
There have been no user-downloadable FW updates for the 2160, only OEM FW which we have no access to.
7558037 is offline
post #15 of 17 Old 08-21-2013, 01:57 PM - Thread Starter
CBK9001's Avatar
It looks like I am out of options and will have to bite the bullet and buy a new DVD recorder. Is there a comparable current model out there that does what mine does?
Basically, looking for one that has a hard drive to record programs to and can burn DVDs as well.
Any input would be appreciated.
CBK9001 is offline
post #16 of 17 Old 08-21-2013, 02:04 PM
Guest
Quoted: 38 Post(s)
Liked: 198
New Mag units are the 53x Series, as described here.
Links to sellers and other stuff in Section 11 of list on pg 1 of my Sticky thread... click on 1st link in my sig. line below.
7558037 is offline
post #17 of 17 Old 08-22-2013, 01:54 PM - Thread Starter
CBK9001's Avatar
CBK9001 is offline
