Copying to the 515 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-11-2013, 04:34 PM - Thread Starter
ulrich13's Avatar
I want to record some old beta tapes to DVD using the Magnavox 515.
When I connect the beta machine to the front of the 515 I get audio and no video. When I connect to the back I get video and no audio.
Has anyone else had this problem?
ulrich13 is offline
post #2 of 3 Old 08-11-2013, 05:00 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
You need to connect composite YWR RCA or S-Video+W/R audio to either the back or the front, then open the Video > Video Input menu and select the appropriate input type... L1 (back) or L2 (front) "Video In" if YWR RCA or "S-Video In" if S-Vid.
wajo is offline
post #3 of 3 Old 08-11-2013, 06:42 PM - Thread Starter
ulrich13's Avatar
Thank you. I didn't know about the input menu.
ulrich13 is offline
