Magnavox H2160WM9 A shutting off - AVS Forum | Home Theater Discussions And Reviews
Old 08-27-2013, 03:38 PM - Thread Starter
darrabito's Avatar
My 2009 Magnavox H2160WM9-A DVR keeps shutitng off by itself. When I turn it back on it displays the flashing letters "SEI"
darrabito is offline
Old 08-27-2013, 04:00 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
That's a System Error 1 and can usually be eliminated by unplugging power for 10 minutes and replugging.
If it comes back to --:-- in the clock display, start setup over (Clock, etc.) and you should be OK. If not, you could then do a Soft Reset, as described here
wajo is offline
Old 08-27-2013, 05:08 PM - Thread Starter
darrabito's Avatar
Noticed fan quit working. Opened her up and removed dust. Fan is now turning so I hope that was the problem. Been working now for 4 hours without shutdown.
Old 08-27-2013, 05:11 PM - Thread Starter
darrabito's Avatar
Thanks. It may have been the dirty fan but I have noted your reply as well....
