Funai problems - AVS Forum | Home Theater Discussions And Reviews
Old 09-30-2013, 04:53 AM - Thread Starter
Funai-Guy's Avatar
Hi iam nw here so please bear with me!! Ok I have a Funai hdr b2735d recorder nice interface and easy to use. Here is the problem: the dvd section will no longer format disks even though they are the correct ones and have used these in the past. Have cleaned the laser with cotton bud and a little water this worked for a while now it won't even record to a previously formated disk?
I have looked at the pcb that the deck is connected to
For any pots that may be adjusted but can't see any.
Any ideas what is wrong and apart from the laser what other component(s) might need changing and where can you succesfully get parts for this recorder many thanks smile.gif
Funai-Guy is offline
Old 09-30-2013, 10:11 AM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
You might want to clean the rubber hub atop the DVD Drive turntable. See this post:
http://www.avsforum.com/t/940657/magnavox-537-535-533-515-513-2160a-2160-2080-philips-3576-3575/12240_60#post_19647592
To find a Funai Service Centre in the UK ring-up 0870-3833010 or email service@funai-uk.com for more information.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Old 10-01-2013, 03:52 PM
profhat's Avatar
Acording to Funai your DVD MECHANISM & DVD/HDD MAIN CBA ASSEMBLY is Part Number: N78GMBBN
Anyway check here the Service Manual. Good luck.
http://elektrotanya.com/funai_hdr-a2635-a2835-b2735-d2835-e434aed_bed_cbd_eed.pdf/download.html
profhat is offline
