Magnavox HDD DVD Recorder Issue-Recording with HQ Speed - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2013, 09:15 AM - Thread Starter
classrock's Avatar
I have had this unit for a couple of months and love it! Normally i use the SP speed setting, but decided to try the HQ Speed. The playback of the recorded show was extremely jumpy. Is there some adjustment I should make it my settings to fix this problem? The recording was made through the unit's tuner (Local HD channel).
classrock is offline
Old 10-12-2013, 11:17 AM
Quoted: 860 Post(s)
Liked: 348
I have made/make all of my recordings at HQ with a 2160A and 515H. I have never seen this issue.
I would try component if you are using HDMI (or visa versa). Magnavox has a very active forum. Try there.
JoeKustra is online now
