Magnavox MDR535H - MDR535H/F7 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 91 Old 07-25-2014, 09:32 AM
Ron365's Avatar
I have never performed the SKIP013 so I am going to give that a try. My logic was the disk drive works great meaning that the operating system was ok. I believe you are steering me to continue testing and not throw money at a new hard drive which may not fix my problem. The SKIP079 showed no problem with the DVD or hard drive.
Ron365 is offline
post #62 of 91 Old 07-25-2014, 09:39 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Look at my last post and try those suggestions first... SKIP 013 takes a long time to complete, without any ongoing feedback until media check is done (the entire disk surfaces).
7558037 is offline
post #63 of 91 Old 07-25-2014, 09:49 AM
Ron365's Avatar
Too late. I have already started this program. So far everything is passing at least the first three milestones.
Ron365 is offline
post #64 of 91 Old 07-25-2014, 09:56 AM
Ron365's Avatar
In looking at this problem again, again. It may not be a disk problem but an operational problem. What tells the HDD to turn on? Should be the timer. I was under the assumption that what turns the HDD on is the same as what turns on the DVD to record. If the operational system is currup that turns the HDD on. How can this be repaired. You would think that this is a software program?
Ron365 is offline
post #65 of 91 Old 07-25-2014, 10:04 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Do these things first for more data points:
1. Select the HDD drive then press REC to see if will record to the HDD manually.
2. Set up a timer program for recording to a DVD, don't insert a DVD, and let it record (hopefully) to the HDD (alternate auto-switch recording function). You only need a 1-minute timer for this.
7558037 is offline
post #66 of 91 Old 07-25-2014, 10:10 AM
Ron365's Avatar
My Magnavox just finish the SKIP 013 test. All passed. But, this of course does not fix my problem or does it? If doing the factory test exercise the HDD maybe I should go back and try to use the HDD again. I will do as you suggested and do a manual record and check the alternate auto-switch recording function.
Ron365 is offline
post #67 of 91 Old 07-25-2014, 10:23 AM
Guest
Quoted: 38 Post(s)
Liked: 198
HDD mechanics and electronics all OK, so we're narrowing it down to .... ?
7558037 is offline
post #68 of 91 Old 07-25-2014, 10:36 AM
Ron365's Avatar
It passed the manual recording no problem. I did as you requested in putting in a time recording for the DVD without placing the DVD in the tray. We have to wait as at first the time recording wanted me to place a disk in the tray. I had to alternate the time a little in the future to allow for the time recording.
Ron365 is offline
post #69 of 91 Old 07-25-2014, 11:14 AM
Ron365's Avatar
Works as advertised. Automatically switched to the hard drive. So where do we go from here. The hard drive is unreliable for time recordings. Yet, it test out ok. This would mean putting in a new hard drive would not fix my problem? As it is a timer problem? But, how come the removable disk continues to work without any problems?
Ron365 is offline
post #70 of 91 Old 07-25-2014, 11:21 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Now, do a manual-timed recording to the HDD on HQ rec mode for max. hours allowed... press REC multiple times until the time shown on screen = 6 hours. Do that again if you've been recording and deleting for awhile, until you get enough hours recorded that you think the recordings are all on NEW HDD sectors. (You can Edit - Protect those long HQ titles if you think someone might delete them too soon, before more tests.)
Then, set some "normal" timers for a few shows (as many as will test its timer recording ops now) and see if/how it works with your most-used HDD sectors "out of action" with those manual HQ recordings.
7558037 is offline
post #71 of 91 Old 07-25-2014, 12:18 PM
Ron365's Avatar
Thanks. This will take me awhile to do. Have a nice weekend.
Ron
Ron365 is offline
post #72 of 91 Old 07-26-2014, 12:24 PM
Ron365's Avatar
Recorded with no problem. I am going to put my regular schedule to the hard drive instead of the removal disk for Monday. I am hoping that the factory reset SKIP013 did the repair and that everything is working properly now.
Ron365 is offline
post #73 of 91 Old 07-26-2014, 01:50 PM
Guest
Quoted: 38 Post(s)
Liked: 198
I hope you left those test titles on the HDD so they are isolating the most-used sectors and they won't come into play again!
Keep them in place for a long while.
7558037 is offline
post #74 of 91 Old 07-27-2014, 09:46 AM
Ron365's Avatar
Thank you for the help. I will let you know if it works.
Ron
Ron365 is offline
post #75 of 91 Old 07-27-2014, 02:53 PM
Guest
Quoted: 38 Post(s)
Liked: 198
While still fresh in your mind, how long did the SKIP 013 test take on your 533?
7558037 is offline
post #76 of 91 Old 07-27-2014, 08:45 PM
profhat's Avatar
Bah, wrong place.
profhat is offline
post #77 of 91 Old 07-28-2014, 11:20 AM
Ron365's Avatar
Quick. It was less then an hour. To tell you the truth I started it then walked away. It recorded two shows this morning (Monday 7/28/2014) on two different channels, two different times with no problems. My fingers are crossed that it will continue to record correctly.
Ron365 is offline
post #78 of 91 Old 07-28-2014, 11:23 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Great... hope it continues!
I'd like to know how long that SKIP 013 took on your 533 (for the help files).
7558037 is offline
post #79 of 91 Old 07-28-2014, 11:33 AM
Ron365's Avatar
Magnavox MDR533 H?F7
Sorry about that. I did not record the time for the SKIP013. As I reply in the previous message, I started the SKIP013 and walked away. Went back approximately an hour and the display was flashing and unplugged per direction. If I repeat this procedure (SKIP013) I will record the time and get back to you.
Ron365 is offline
post #80 of 91 Old 07-28-2014, 12:42 PM
Guest
Quoted: 38 Post(s)
Liked: 198
Not important since it appears to take the same time as my older 160GB unit, even tho HDD is larger... CPU speed increased?
7558037 is offline
post #81 of 91 Old 07-28-2014, 12:56 PM
Ron365's Avatar
Beyond me. I have been using my Toshiba DR570KU to back up my recordings. Glad to give it a rest now that the Magnavox 533 is working again.
Thanks again for all your help,
Ron
Ron365 is offline
post #82 of 91 Old 11-04-2014, 03:16 PM
Ron365's Avatar
Magnavox E48 code MDR533H 320GB
My unit is giving E48 codes again. I was recording just one show and the E48 code (can not recorder to this HDD ) was displayed. I still believe I have a bad hard drive in this unit. In the past, we did SKIP 079 AND SKIP 013 which did it working again. For the last couple of weeks I have been using the removable disk to make all of my recording and it has worked without failure. The removable is slower but I am happy that I still can record with this unit.
Ron365 is offline
post #83 of 91 Old 11-24-2014, 12:31 PM
Ron365's Avatar
Magnavox MDR557H/F7
I purchased anotherr Magnavox to give my two year old MDR533H/F7 a rest. I am still having error code 48. It passes SKIP 079 and skip 013. The unit will not record to HDD. In the past I had two time recording and it would do the first and not the second. Currently, I was only had one time recording which it would not record. I still believe it has a bad hard drive as the removal disk never has a problem recording.
Ron365 is offline
post #84 of 91 Old 11-24-2014, 01:33 PM
gastrof's Avatar
Quoted: 118 Post(s)
Are you saying your NEW Magnavox is also giving you error code 48 messages, or the old one is?
Also, what model did you buy, with regards to your new one?
gastrof is offline
post #85 of 91 Old 11-24-2014, 01:58 PM
Ron365's Avatar
MRR557H/F7 Magnavox
Sorry for the confusion. I just purchased a MDR557H/F7. The unit that is giving me error code 48 (can not record to this HDD) is a Magnavox MDR533H/F7. It just two years old and has been a problem after the warranty ran out (one year). It passes all test but continues to give me problems recording to the HDD. The removable disk continues to record without any problems.
Ron365 is offline
post #86 of 91 Old 11-26-2014, 08:00 AM
gastrof's Avatar
Quoted: 118 Post(s)
... The unit that is giving me error code 48 (can not record to this HDD) is a Magnavox MDR533H/F7. It just two years old and has been a problem after the warranty ran out (one year). It passes all test but continues to give me problems recording to the HDD. The removable disk continues to record without any problems.
Yeah. I'd say the hard drive has gone wonky. You absolutely can put a new hard drive in there (at least you can with the older ones) and the machine will "format" it (or whatever) itself. Wajo has instructions on what to do...somewhere around here.
Your experience, tho', is pretty rare. I've had several of these machines over the years, and currently own three. The only time I have trouble recording to the hard drive is when the drive is totally full and won't hold any more....which does at times happen. Heh.
gastrof is offline
post #87 of 91 Old 02-16-2015, 11:02 AM
Ron365's Avatar
Vervatim DVD+RW, DVD-RW, Magnavox DVR
I noticed that the newer Magnavox MDR557H no longer mentioned the use of DVD+R. I have been using them in the Magnavox MDR533H with no problem and it is mentioned in the owners manual. The reason this came up is that DVD+RW recorded in the MDR557H will no longer play in my Sony player. Where as the DVD+RW recorded in my MDR533H has no problem. I find it strange that they have removed the +RW from the the newer Magnavox MDR557H manual. Does anyone know what is going on?
Ron365 is offline
post #88 of 91 Old 02-16-2015, 11:55 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Other users have reported that +R can be played and recorded in the 557, even tho the manual doesn't mention them (+RW might be iffy). The +R still need to be Finalized to play in other players.
7558037 is offline
post #89 of 91 Old 02-16-2015, 12:16 PM
Ron365's Avatar
Magnavox MDR557H Finalize disk
When recoding on the MDR 533 the DVD+RW were never finalized and they had no problem on play back on other players. With the newer MDR557 this is no longer the true. I have tried the "Finalize"page 64 owners manual and it did not make any difference when using the DVD+RW. They continue to be rejected by my Sony player. Per your suggestion I will purchase some DVD-RW and see if I can get them to work on my MDR533. The loss of the ability to take the removable disk and use on other players is a real loss in value for this recorder.
Ron365 is offline
post #90 of 91 Old 02-16-2015, 12:23 PM
Ron365's Avatar
When playing disc on other DVD players should the setting be on "Auto Finalize" on Disk full or end of timer rec? Reference: page 65 owners manual.
Normally my removal disk has recorded only one or two shows, maybe two hours worth. You would think to set it at end of timer rec but what would that do for multiple recordings on the same disk?
Ron365 is offline
