AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DVD Recorders (Standard Def) (http://www.avsforum.com/forum/106-dvd-recorders-standard-def/)
-   -   dmr-es10 large border around screen (http://www.avsforum.com/forum/106-dvd-recorders-standard-def/1515575-dmr-es10-large-border-around-screen.html)
chapan 02-02-2014 06:39 AM
I have a dmr-es10 connected via coax cable to Time-Warner. When I record a program on a DVD-RAM it records in the proper aspect ration of 16:9 but there are large borders around the image. When I play back on a TV I have to change the TV settings to fill the screen. Any ideas on how to get it to record without having those borders around the image?
Kelson 02-02-2014 03:16 PM
Please define this.
Do you have the cable from the wall going into the Rf in on the back of the ES10? Or do you have a cable from the Rf out of the cable box into the Rf in of the ES10
chapan 02-02-2014 05:53 PM
I have the cable from the wall directly into the ES10.
jjeff 02-03-2014 05:00 AM
It sounds like your recording from the analog channels which may very well be of the postage stamp aspect(4x3 and letterboxed). As you said you can zoom this image to fill your screen in proper aspect ratio but the picture quality will suffer. Nothing you can do about this if this is the way the channels are broadcast on your cable system. If you got a HD cable box more than likely it would be full screen 16:9 but that wouldn't really help your recording issue, only viewing via HDMI or component.
chapan 02-04-2014 06:35 AM
When I connect the same cable to a TV it looks exactly the same, so it is not a dmr-es10 issue.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
