Model DMR-EX87 Panasonic Recorder new laser fitted, but wont record or play RW or Ram disks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-06-2014, 05:30 AM - Thread Starter
Petepots's Avatar
Hi Guys
Just fitted a new laser RAF3331A-C to my Panasonic recorder as it did not play any disks and the laser was clear of dust and dirt that's why it was replaced
So after fitting the RAF3331A-C laser unit all looked ok and it played all bought Dvd's and plays and writes to -R disks but cannot read Ram or RW's.
The Rw's disks I was trying were disks that had been made on this unit with files on them.
Its like there is not enough power to the laser to read or burn Ram or Rw's disks
Can anyone give me an idea what I should do now!!
Peter
Petepots is offline
post #2 of 5 Old 02-07-2014, 12:36 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
Your best bet for an informed answer about your unit would be AVS user MICKINCT. Try sending him a PM.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is online now
post #3 of 5 Old 02-07-2014, 04:01 AM - Thread Starter
Petepots's Avatar
Thanks for your advice but I cannot see where I can send a PM. Is this because I am new to AVS
Petepots is offline
post #4 of 5 Old 02-07-2014, 11:15 PM
Quoted: 111 Post(s)
Liked: 86
Sorry. In the far upper right hand corner of the AVS screen are some links, one of them is "Private Messages". Click on that, then click "Compose New". Enter mickinct as the name to send to, and your subject and message.
Luke
post #5 of 5 Old 02-08-2014, 05:49 AM - Thread Starter
Petepots's Avatar
Got It
Thank you lets hope he can help
Kind regards
Peter
Petepots is offline
