Dubbing WS from HDD to DVD - AVS Forum | Home Theater Discussions And Reviews
Old 02-10-2014, 02:27 PM - Thread Starter
ToadB's Avatar
Recently connected my Mag 515 to an OTA antenna and wanted to archive some Downton Abbey HD episodes from the HDD where they are in 16:9 (HQ) to DVD. My test dubs result in a 4:3 picture and searching the forum, this appears to be normal. Just wanted to ask if perhaps I am missing a setting or a workaround that would give me 16:9 on the DVD without losing any more quality. TIA for your help!
Bill
Pan 60ST60, Mag MDR515, Pan DMR-Z28, Oppo BDP- 103, Marantz SR5007, AppleTV 3G, Moto DCX-3400M
ToadB is offline
Old 02-10-2014, 02:31 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The Mag should have no problem dubbing a true 16:9 program recorded on a digital channel to its own HDD in "16:9 Wide" (setting in Video > TV Aspect) to a DVD with same setting, and TV set to display Wide, or stretched, or whatever. Only real unknown is if played on a different player/recorder, but mine play nice on Panasonic, Samsung, and other devices here.
Did you use HIGH (high-speed dub, HSD) or real-time dub? Might want to try a recording with proper settings in SP, dubbed to DVD with HSD, and see if any diff under same conditions.
wajo is offline
Old 02-10-2014, 04:36 PM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
Assuming you have your Magnavox set to 16:9 wide you should be getting anamorphic recordings. Now the Magnavox like almost all standalone DVDRs don't set the WS(wide screen) bit but the way around that is to set your DVD player to WIDE or FULL for 4:3 discs, if your DVD player lacks such a setting then most all 16:9 HDTVs have a FULL or STRETCH setting that will decompress the 4:3 anamorphic recording and display it in it's proper 16:9 aspect.
The WS bit is what tells your DVD player to stretch a 4:3 anamorphic frame to true aspect 16:9, all WS DVDs including commercial are recorded in this format, 4:3 is the format for DVD but by utilizing anamorphic recording one can store a 16:9 frame in a 4:3 container.
jjeff is offline
Old 02-10-2014, 07:43 PM - Thread Starter
ToadB's Avatar
Thanks very much, gentlemen! I'll check the settings on the Oppo. It does a very good job of zooming to full screen, just wanted to make sure I was getting the best quality out of the Mag 515.
Bill
ToadB is offline
Old 02-10-2014, 10:29 PM - Thread Starter
ToadB's Avatar
Yup! Changed TV Aspect ratio setting on the Oppo from 16:9 Wide/Auto to 16:9 Wide and got full screen on the DVD from the Mag 515.
4:3 DVDs have a low WAF at this house so don't think we will overly miss the black bars.
Smart and helpful people around here - not only did the tip work, i learned why it worked!
Thanks again!
Bill
ToadB is offline
Old 02-11-2014, 05:12 AM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
The downside to that setting is even when you play a non anamorphic DVD it will still stretch the 4:3 frame to 16:9 resulting in stretched or fat people, if this really bothers you, you can change the setting back, but with me the vast majority of the things I play are 16:9 so I generally just live with a few stretched 4:3 programs, besides as you said it gets rid of the wide black bars on the side.
Lastly even with the setting set to stretch 4:3 material to 16:9 it will not double stretch DVDs that are anamorphic and actually have the bit set(like commercial DVDs) so no worries there, commercial WS DVDs will still look correct.
jjeff is offline
