DMR-EH75V DVD drive not reading, not usual - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-20-2014, 04:37 PM - Thread Starter
LouF66's Avatar
I have a DMR-EH75V that has stopped reading discs.  It is not making the usual noises ("FOUR "chugs" followed by lower-pitched chugs"), but just quietly searches.  I have replaced the laser assy. once (approximately a year ago with near zero post-replacement use), and it recently has started this problem.  I am hesitant to try another laser on a trial and error basis since I am wondering if it could be a pcb controller (?), ribbon cable/connector connection or in fact the laser.
Here is what I have tried:
Service mode routine 4,1, Laser used time:  about 1600 (was not reset when laser assy. was replaced)
Service mode routine 4,2, Last RAM drive error:  No error (I think F00)
Service mode routine 4,4, Laser power:  Nothing reported (because it can't find a disc?)
No error messages on the front display, (U**  etc...)
I have cleaned the spindle and laser
released and reseated ribbon cable at the laser
Any insight would be appreciated.
Lou
Recorder DMR-EH75V
DVD drive VXY1945
LouF66 is offline
post #2 of 3 Old 03-20-2014, 09:38 PM - Thread Starter
LouF66's Avatar
And I never did any alignment procedure after laser installation.  But it did seems to play and record A-OK.
LouF66 is offline
post #3 of 3 Old 04-01-2014, 03:57 PM - Thread Starter
LouF66's Avatar
Following through with this, I had AVS member mickinct do a repair on this, and it was great service!  It was the laser (again) and power supply capacitor(s) was replaced as preventative maintenance.  Thanks again!
LouF66 is offline
