Mag 2160 finally dead? - AVS Forum | Home Theater Discussions And Reviews
Old 06-15-2014, 07:16 AM - Thread Starter
jokerl90's Avatar
Liked: 0
Background; 2160 connected to cable, passing through to tv. Have done soft reset,hard reset over the years until the clean tuner solution fixed all problems. Thunder storms knocked cable out a couple of times the past few days, always returned to normal. Both 2160 and tv plugged into battery ups.
The Problem; Last night everything normal. This morning 2160 is showing ----/----- on display. Turned it on, reset time, turned it off. Short time later tv looks like all channels are scrambled, 2160 shows no display at all, is dead. Unplug 2160 to do soft reset, tv clears up, plays perfectly. Do soft reset on 2160 no luck, still dead.
To sum it up, 2160 is dead, with it plugged in to power, tv looks scrambled, unplug 2160 from power tv is clear.
So has my old friend finally given up the ghost?
jokerl90 is offline
Old 06-15-2014, 08:23 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
First, disconnect from UPS and leave unplugged for at least 10 min. Then try one or more additional Soft Resets while plugging directly into a known-good wall socket, not the UPS.
Make sure you've allowed enough time to drain residual power before replugging into wall socket, that you're using the power button on the unit (not on remote). and you hold the power button in until you (hopefully) see the dashes in the display again.
wajo is offline
Old 06-15-2014, 02:45 PM - Thread Starter
jokerl90's Avatar
Liked: 0
Thanks for the reply wajo! Got it to power up, saw that the channels were checked for antenna (should be for digital). Before I could do the clean tuner procedure it went down again. Going to try to get it powered up again with the cable coax disconnected and try the clean turner again.
Again, thanks for the reply.
jokerl90 is offline
Old 06-15-2014, 07:54 PM - Thread Starter
jokerl90's Avatar
Liked: 0
It's Alive!!
Had to go inside it and press the reset switch, almost forgot about that one. Entered each channel manually, set the time, seems to be working fine.
Oh, not that it matters, but it's a 2080 not a 2160.
Thanks for the help!
jokerl90 is offline
