Replacement DVD Drive for Panasonic DMR-EZ475V? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-09-2014, 04:06 PM - Thread Starter
Liked: 0
First, a disclaimer: I fully agree with prior comments about the DMR-EZ47 series not being one of Panasonic's better products. Having said that...............
1. Is there an aftermarket DVD-RW drive that is fully compatible with the DMR-EZ475V? My machine was manufactured in April 2007. The drive has PXY 1961 and 740467RC and 120v 30W 60 Hz written on it.
2. If I replace the drive, will it be ready to go immediately or is some type of programming and/or software updating necessary?
This machine worked well for 18 months, then suddenly it wouldn't read any disks....blank, pre-recorded, etc. I took the case off and cleaned the lens on the drive but still nothing.
Josh Hemminger is offline
post #2 of 4 Old 07-09-2014, 04:49 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
I think you will have to scour Craig's List for a cheap parts machine. That may be tough find though because the DVD drive is usually the part that goes bad and turns it into a parts machine.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #3 of 4 Old 07-09-2014, 04:56 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Panasonic DVD Drives are proprietary in design. There is no generic substitute for the VXY1961. Compatibility considerations are addressed in this thread:
Swapping Panasonic DVD Drives, Compatibility Considerations
Basic DVD Drive diagnostic information/advice is found in this post:
Panasonic DVD drive spindle/hub cleaning, includes remedial procedures for reassembly complications
If you need a new laser assembly (optical pick-up) installed you should send a private message to mickinct.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #4 of 4 Old 07-09-2014, 05:44 PM
mickinct's Avatar
Quoted: 201 Post(s)
Liked: 901
Sent a pm to member
MickinCT
mickinct is online now
