Recording problem with Magnovox MDR557H - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-02-2014, 11:16 PM - Thread Starter
Liked: 0
I did the initial setup with a new Magnavox MDR557H tonite and have a problem with the record option. When I use the record option the unit displays random numbers as it's recording, and the same numbers are posted on the TV screen as well as the red record button. The unit records the show ok, but the numbers and the red record button never disappear from the TV screen. Any ideas? Thanks in advance, goldhawk.
goldhawk is offline
post #2 of 4 Old 08-03-2014, 08:51 PM
gastrof's Avatar
Quoted: 118 Post(s)
Did you consider posting this question in the thread already dedicated to this recorder, instead of starting a whole new thread?
I'd also explain what you mean by "random numbers" and 'the red button never disappears from the TV screen'. (For example, with regards to the 'red button', do you mean it stays on screen even after the recording is over?)
gastrof is offline
post #3 of 4 Old 08-13-2014, 10:05 AM
Liked: 0
funny numbers
"random numbers" may be what I experienced with two different Magnavox units. When REC is pressed, the system quickly cycles through the pre set recording times (30, 1, 1:30, etc.) At the same time the red record light is displayed. The time left count down number acts like the system is recording. However pressing STOP causes a brief symbol flashing and the systems continues to cycle the numbers as before. The only way to stop the unit is to turn it off and then the current recorded program is lost.
This happened to me on both a new MDR533H/F& and a new MDR 557H/F7. Magnavox tech support lady was no help at all. She simply tried to read the instruction manual and apparently had no technical background.I returned both machines (through Amazon) and have no idea what to do for a HDD DVD recorder.
Ferd Spot is offline
post #4 of 4 Old 08-13-2014, 10:45 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
What you're describing is One-Touch Recording, which normallt requires multiple presses of the REC button, which adds manual recording time in 15-min. increments (557) or 30-min. increments (533). It usually works like this: select HDD or DVD (with DVD inserted), press REC, recording starts, press REC again and 1st 15-min. shows on screen (meaning the current recording will continue for 15-min.), press REC again and display shows 30-,in., press REC again and display shows 45-min., etc. You do NOT hold the REC button, just normal press each time.
While recording, the front-panel display will count down from the total time you set by pressing REC multiple times.
To STOP a recording, press AND HOLD the STOP button until you see a dialog asking your to confirm that you want to stop the recording... a precaution against "accidental" stopping of a recording.
wajo is offline
record icon stays on tv with magnavox mdr557h
