Do DVD 'player' universal remote codes work for DVD recorders? - AVS Forum
post #1 of 4 Old 11-10-2014, 10:46 AM - Thread Starter
Costanza's Avatar
Question Do DVD 'player' universal remote codes work for DVD recorders?
I'm interested in buying a DVD recorder / hi-fi VCR combo locally for cheap.
It's a Pioneer without a remote but my Harman Kardon AVR154 universal remote has codes for Pioneer DVD players, but doesn't specify recorders. Will it work? Never owned a recorder before.
Costanza is offline
post #2 of 4 Old 11-13-2014, 11:41 PM
mdavej's Avatar
Quoted: 758 Post(s)
Liked: 484
No
mdavej is offline
post #3 of 4 Old 11-14-2014, 07:22 AM
Liked: 0
I've had good luck buying used replacement remotes for 3 different DVD recorders (2 Panasonics and a Toshiba), via Ebay and one of the remote resellers on the web. They were each around 20 bucks and all work perfectly.
I've also programmed a new universal remote to work with my Sharp recorder, and it's OK for the basic functions. The problem arises when I want to set it up for timed recording. The buttons I need for some functions just aren't there on a universal.
Josh Hemminger is offline
post #4 of 4 Old 11-14-2014, 08:20 AM
mdavej's Avatar
Quoted: 758 Post(s)
Liked: 484
A $3 cable TV remote will also perform every possible function for any recorder, including Sharp. Post the models and I can post a recommendation and all codes.
mdavej is offline
