Magnavox 2160 recording question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-04-2015, 07:07 AM - Thread Starter
Rickenbacker's Avatar
I have a Magnavox 2160 and I burn DVD's of music videos that I have recorded off my hard drive. I would like to re-burn the DVD's onto my hard drive from the DVD's so I can edit out videos that I don't want. I am not sure if this is possible. Or to make a complete copy of the DVD onto my hard drive that I can edit later. I used to have a Panasonic EH50S that would let me do this. Is there any way that this is possible with my Magnavox? I appreciate everyone's expertise in this group, that's how I got to but the Magnavox in the first place TIA
Rickenbacker is offline
post #2 of 3 Old 06-04-2015, 08:17 AM
Kelson's Avatar
Quoted: 2008 Post(s)
Liked: 1201
Why don't you use your PC to do this instead. You won't have any video quality loss using a PC like you will if you re-record the disk to a DVD recorder. Just get an editing/authoring program which will import the titles, allow you to edit what you don't want then re-author and burn to a new DVD-R.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #3 of 3 Old 06-04-2015, 08:24 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Yes, you can Dub DVD>HDD as described in this help file. Method depends on whether the DVDs are Finalized or Unfinalized.
7558037 is offline
