DVDR and a S-VHS recorder- Best hookup/same TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-18-2003, 11:40 PM - Thread Starter
HoustonGuy's Avatar
I want to enable both to record the same program this fall at the same time. What is the best way to hook this up for optimum PQ? I hope this is the right forum. I think it is relevant because so many now are buying DVDR's but want their SVHS recordings and playback on the same TV. Also assume many outputs and inputs on new model TV. Links welcome.
The Lab called: Your Brain is ready.
HoustonGuy is offline
post #2 of 11 Old 07-19-2003, 01:25 AM
videojanitor's Avatar
Before anyone can answer that, we need to know what your SOURCE is going to be. Or it could be multiple sources, like antenna, a DSS system, cable, etc. --Bill R.
videojanitor is offline
post #3 of 11 Old 07-19-2003, 03:07 AM - Thread Starter
HoustonGuy's Avatar
cable box which I bet is the majority at least in the USA. Thanks for pointing that out. It is critical.
post #4 of 11 Old 07-19-2003, 11:55 AM
OK, next question then: What kind of OUTPUTS on your cable box? Does it have:
1. Composite video? If so, how many?
2. S-Video? Again, how many? (more than one seems unlikely)
3. RF (most certainly)
--Bill R.
post #5 of 11 Old 07-19-2003, 04:37 PM - Thread Starter
HoustonGuy's Avatar
component out but the cables are going to the TV HD inputs(however I would also appreciate a same cable box component analysis for another TV without HD), s-video(1), composite video in/out, optical out(SPDF) coaxial out(SPDF), composite audio out/in,RF. Thanks
post #6 of 11 Old 07-19-2003, 10:51 PM
I gotta admit, you've got me a bit confused now. I can't really tell from your last post what ins/outs are on the cable box and what's on the TV. So, for the sake of clarity, please give me a list of just the OUTPUTS on the cable box, other than the component output which you said is already in use.
--Bill R.
post #7 of 11 Old 07-19-2003, 11:50 PM - Thread Starter
HoustonGuy's Avatar
VJ - here are the outs only, sorry( why in the freak would you have ins anyway on a cable box?, but they are there.)
component out but the cables are going to the TV HD inputs(however I would also appreciate a same cable box component analysis for another TV without HD), s-video out(1), composite video out, optical out(SPDF) coaxial out(SPDF), composite audio out/,RF. Thanks
post #8 of 11 Old 07-20-2003, 05:54 AM
vferrari's Avatar
PMFJI, Perhaps to up-convert a video source's composite output to component/s-video. You feed it into your cable box and it gets fed to your tv as component or s-video. Also helps if your tv has only one or two video inputs.
Vic
The Future ain't what it used to be...
vferrari is offline
post #9 of 11 Old 07-20-2003, 01:28 PM
HoustonGuy ...
Well based on what you've told me, I'd hook it up like this:
Take the S-Video and L/R audio outs and feed them into your DVD Recorder. The take the composite video out and L/R/ audio and feed them into your S-VHS machine. Yes, you will lose the advantage of S-Video, but given the "not-so-great" quality of cable signals, I don't think it will matter much, and it greatly simplifies the hookup. Plus, you probably want the best signal going to the DVD recorder.
Note that if the cable box on has ONE set of L/R audio outputs, you can simply put a "Y" splitter on each to obtain two. Can't do this with VIDEO though -- only audio.
Does this answer your question? --Bill R.
post #10 of 11 Old 07-20-2003, 06:03 PM - Thread Starter
HoustonGuy's Avatar
vj- I neglected to tell you I have a receiver involved here. How would that change the audio hook ups?
post #11 of 11 Old 07-21-2003, 01:48 PM
If you just need another audio output from the cable box, you can split it again -- typically with consumer stuff, you can "bridge" an audio source among many inputs without any problems (I've got the audio out of my satellite system going into SEVEN different devices, with no ill effects).
--Bill R.
Closed Thread DVD Recorders (Standard Def)
