Buying the E-80 for $500 on the internet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-31-2003, 11:50 PM - Thread Starter
HoustonGuy's Avatar
There have been several Ebay ads recently offering Buy it Now for this price. I am sure a lot of people want to know whether warranties are valid etc. This recorder will be the hottest one over the next 4-6 months, absolutely no doubt. Give the new buyers your professional opinions if you can. I have talked to some friends who did this and their units were sealed box and worked. How they can sell this low is a mystery, since this can not be far from cost.
The Lab called: Your Brain is ready.
HoustonGuy is offline
post #2 of 11 Old 08-01-2003, 11:47 AM
Timbeau's Avatar
I purchased a DMR-E60 on ebay, it was advertised as new sealed box and it was. I called Panasonic about the warranty and they said I only needed a sales slip (PayPal sheet ok) that said it was sealed and had a date.
Timbeau is offline
post #3 of 11 Old 08-01-2003, 12:20 PM
gbrnole's Avatar
just by searching deal time there are a few priced at $519.
newegg has a good deal on refurbished e60's at $335.
gbrnole is offline
post #4 of 11 Old 08-01-2003, 12:29 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Click on the $519 the price has gone down to $499!
I went to a local retailer in the NY area and they would sell it to me for $525!
bad1550 is offline
post #5 of 11 Old 08-01-2003, 07:53 PM
mattack's Avatar
Which one, Abe's of Maine? It sure isn't doing that for me.
mattack is offline
post #6 of 11 Old 08-02-2003, 02:38 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
I believe it was the Pricegrabber.com search!
bad1550 is offline
post #7 of 11 Old 08-11-2003, 10:55 AM
Vidmaven's Avatar
I just got my E-80 from ecost.com for $539 including shipping!
Ordered it online and got it 2 days later.
They only had 4 out of a total of 42 left after I ordered so they may be sold out by now.
It seemed like a great price and I have dealt with ecost before and never had a problem.
I have only had time to record a couple camcorder tapes and edit them for one 6 hour DVD.
I love the hard drive it makes it pretty easy to edit your recordings prior to burning.
The problem with obsessions is that they are insatiable.
Vidmaven is offline
post #8 of 11 Old 08-11-2003, 11:51 AM
potus's Avatar
You used 6-hour (EP) mode for your camcorder transfers?? I would strongly recommend a higher speed mode; at least SP. EP mode is pretty marginal, if you ask me....
I sometimes use LP for time-shifting TV, but that's as low as I'll ever go...
potus is offline
post #9 of 11 Old 08-11-2003, 12:06 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
I plan on archiving TV shows from Direct TV to hard drive when I receive my Panny E-80.
Can you please comment at what speed should I record to hdd? I then plan to transfer to DVD-R (Try to fit as many shows as possible)
Bob
bad1550 is offline
post #10 of 11 Old 08-11-2003, 12:46 PM
potus's Avatar
I really can't comment on DirectTV, since I don't have it.
For over-the-air, SP (2Hr) seems to be pretty good. If you really want to jam as many programs on a disk as possible, LP (4hr) is ok, but obviously inferior... LP has a drop in resolution as well as higher compression rate.
You really have to try them for yourself and see.
potus is offline
post #11 of 11 Old 08-12-2003, 01:53 PM
htpartyshack's Avatar
Just ordered one for $549 including shipping from buydig.com. ecost was a bit cheaper, but they had some really horrible feedback so I went with buydig.
htpartyshack is offline
Closed Thread DVD Recorders (Standard Def)
