LG GSA-4040B: DVD-R and DVD+R, DVD-RW and DVD+RW, and DVD-RAM.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-02-2003, 01:52 PM - Thread Starter
ConceptVBS's Avatar
ConceptVBS is offline
post #2 of 12 Old 08-02-2003, 05:59 PM
C44335's Avatar
The first true Multi-Format drive.
I wonder how it stacks up to the
Panasonic LF-D521 in quality and software included ?
The speeds are not very good on the Panasonic.
DVD-R x1 (correction x2)
DVD-RW x2 (correction x1)
DVD-RAM x2
LG
DVD-R x4
DVD-RW x2
DVD-RAM x3
DVD+R x4
DVD+RW x2.4 ?
I was trying to read the box from about 10 feet, The eyes ain't what they used to be.
Have You Hugged A Curve Lately ?
C44335 is offline
post #3 of 12 Old 08-02-2003, 07:36 PM
vferrari's Avatar
Just to set the record straight:
For the Panasonic 521:
DVD-R X2
DVD-RW X1
DVD-RAM X2
Doesn't change the fact that the LG looks like a better drive on paper.
The Future ain't what it used to be...
vferrari is offline
post #4 of 12 Old 08-02-2003, 08:43 PM
SoPa's Avatar
* Check also new Pioneer DVR-A06U recordable drive for PC.
(DVD-R: 4x / DVD-RW: 2x / DVD+R: 4x / DVD+RW: 2.4x)
1. http://www.pioneerelectronics.com/Pi...,93032,00.html
2. http://tomshardware.bizrate.com/mark...U,ir--461.html / http://tomshardware.bizrate.com/buy/...=460103&sort=5
3. The following site is good. (sorry, it's japanese, but you can see developers and internal picture of DVR-A06U drive)
-----> http://ad.impress.co.jp/tie-up/pioneer0306/index2.htm
* Panasonic also will release new 3X DVD-RAM & 4X DVD-R recordable drive for PC in japan. (LF-M621JD & LF-M660JD)
(Panasonic recordable drive can accept cartridge type DVD-RAM. No need of disc extraction.)
1. http://panasonic.jp/p3/multi/m621/index.html
2. http://panasonic.jp/p3/multi/m660/index.html
* NEC new ND-1300A (4X: DVD-R & DVD+R / 2X : DVD-RW / 2.4X : +RW recordable drive.)
http://tomshardware.bizrate.com/mark...--7823147.html
SoPa is offline
post #5 of 12 Old 08-02-2003, 11:24 PM
Brainiac 5's Avatar
Iomega has an all-format drive coming out, which I assume is a rebadged LG or Panasonic; does anyone know which one it is?
Brainiac 5 is offline
post #6 of 12 Old 08-03-2003, 06:35 AM
C44335's Avatar
The iomega more than likely is the LG, since the Panasonic
dosen't do +R or +RW.
The iOmega link.
http://www.iomega.com/na/products/pr...=1059913925886
C44335 is offline
post #7 of 12 Old 08-04-2003, 08:34 PM
Gil T. Pleasure's Avatar
As far as I know, Iomega, I-O Data and Logitec, all of which support all five writable formats, are based on the LG drive.
Body by Nautilus. Brains by Mattel.
Gil T. Pleasure is offline
post #8 of 12 Old 08-05-2003, 05:11 PM
SoPa's Avatar
Exact original manufacturer name of LG optical drive is HLDS (Hitachi-LG Data Storage, Inc.)
For the information go http://global.hitachi.com/New/cnews/E/2000/1005/
PS. And original manufacturer of LG GSA-4040B is HLDS. :cool:
SoPa is offline
post #9 of 12 Old 08-07-2003, 01:54 AM
Londo's Avatar
Will it take DVD-RAM in cart or must they be bare?
You know, I used to think it was awful that life was so unfair. Then I thought, wouldn't it be much worse if life were fair, and all the terrible things that happen to us come because we actually deserve them? So now I take great comfort in the general hostility and unfairness of the universe.
Londo is offline
post #10 of 12 Old 08-07-2003, 05:45 AM
btokars's Avatar
Does anyone know if the LG GSA-4040B can be mounted and will work in an external firewire enclosure. I looked at the specs but could not see anything about Firewire and the company has yet to respond to my e-mail inquiry.
btokars is offline
post #11 of 12 Old 08-07-2003, 05:09 PM
eatswodo's Avatar
Given that it's a standard IDE drive, is there any reason why it *wouldn't* work in an external enclosure, either firewire or USB? Isn't that basically what Iomega will have done with it?
eatswodo is offline
post #12 of 12 Old 08-12-2003, 12:10 AM
EAS
EAS's Avatar
It will work in an external enclosure both usb and firewire.
There aren't many reviews on the drive yet since it's only been on the market for a couple of weeks. Over at dvdrhelp (vcdhelp) there are a few comments..and some neg about problems.
If the problems are only firmware then it's just a matter of time to work out the bugs.
The DVD-RAM is not cart...reports are that it's very fast.
The iomega is the gsa-4040b.
EAS is offline
Closed Thread DVD Recorders (Standard Def)
