Reading DVD-RAM discs in PC DVD-ROM drives? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-04-2003, 08:19 AM - Thread Starter
jerndl's Avatar
Quoted: 31 Post(s)
Can some or all PC DVD-ROM drives read DVD-RAM discs created by the Panasonic recorders? If it only works for some is there a compatibilty table somewhere? I have a HP DVD200i DVD+R/+RW and a Creative PC-DVD 12x DVD-ROM drive am trying to determine if they will read DVD-RAMs. Thanks.
Jay
jerndl is offline
post #2 of 9 Old 08-04-2003, 12:17 PM
Norman Chan's Avatar
Other Maker if stated can playback DVD-Ram than you can if not .... the DVD-Ram disc will not be able to playback in normal DVD drives as per your stated.
Norman Chan is offline
post #3 of 9 Old 08-04-2003, 01:10 PM
gwlbe's Avatar
Toshiba 1712, 30 - 50 bucks, is what you need.
gwlbe is offline
post #4 of 9 Old 08-04-2003, 08:24 PM
Gil T. Pleasure's Avatar
Lite-On DVD-ROM drives (specifically model LTD-166S) can read DVD-RAM discs also.
Body by Nautilus. Brains by Mattel.
Gil T. Pleasure is offline
post #5 of 9 Old 08-04-2003, 09:25 PM
EJ
EJ's Avatar
Not all Lite-On drives will read DVD-RAM...I have one that will not. I ended up getting the toshiba, and have not had any problems.
Former USSB uplink operator.
EJ is offline
post #6 of 9 Old 08-04-2003, 11:08 PM
My bad. So is it just the model I mentioned that reads DVD-RAM disc thne?
post #7 of 9 Old 08-05-2003, 07:46 AM
hroeder's Avatar
There's a complete cross index of drives at www.vcdhelp.com that can let you check out any drive. Basically newer Panasonics, newer Toshibas, and some Lite-ons.
"Wouldn't you gladly resign from the human race if there was another one to belong to?"
Arthur Miller
hroeder is offline
post #8 of 9 Old 08-05-2003, 12:39 PM - Thread Starter
jerndl's Avatar
Quoted: 31 Post(s)
Thanks for the help guys.
Jay
jerndl is offline
post #9 of 9 Old 08-12-2003, 10:40 AM
calebu2's Avatar
I took a DVD-RAM disc created on my DMR-HS2 into CompUSA a couple of months ago and shoved it into every laptop DVD drive I could get to without removing the security bar.
First, to my surprise, squashing random DVD media into laptop DVD drives and messing around with WinDVD and the system device info on WinXP did not get a single salesperson to stop and help me/escort me out of the store. I don't know what it is about me that makes stores think I don't need or want their assistance, but I always seem to get ignored (Unless I walk around flashing my best buy card and looking at the most expensive item in that section of the store - then I might get help).
Secondly, and more on topic - at least 60% of computers on display (based on machines with unique DVD-ROM drive models) could play a DVD-RAM disc without any additional messing around or software.
Not surprisingly, the Toshibas generally had a compatible drive - the HP Pavilion laptops were mixed (My 2yr old n5390 can) and the Sony's either didn't or had their drive in a place where I could not open it without store assistance.
I also found that the majority of the hand held DVD players could NOT read DVD-RAM discs.
If I ever find the piece of paper where I wrote down the machine models and drive models, I'll have to post it (or add it to the database) - but it is well worth taking in some blank media when buying a laptop to see what it can play (if you plan on using DVD-Rs or DVD-RAM)
Steve
calebu2 is offline
Closed Thread DVD Recorders (Standard Def)
